Astir Locking Collars
Old August 25th 13, 11:57 AM posted to rec.aviation.soaring
Astir .
Default Astir Locking Collars
Has anyone got any definitive documentation regarding the fitting of "thin"
shims on Astir wing spigots that are approaching the 5mm limit on collars
I recall having something a few years ago, but unable to retrieve it
Fully aware of the engineering logic of too thick shims and ball/spigot
relationship
Old August 25th 13, 01:41 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
relationship
Are you saying that the 'little balls' inside your locked lift fittings, have reached the bottom of the spigot 'groove' and the wings are not tightly secured to the fuselage and you are considering rectifying this condition using shims?
Old August 25th 13, 02:54 PM posted to rec.aviation.soaring
Astir .
The rotating collars are locking the wings correctly, the FM states there
needs to be a 5mm gap shown on the locking collar, which is now
approaching
The paperwork I had as far as I recall was from Grob to the UK air cadets
who flew a fleet of Grob gliders, which stated that a thin shim could be
placed onto the wing spigots to take up wear. In "little balls"
"thin"
collars
relationship
Old August 26th 13, 02:29 AM posted to rec.aviation.soaring
I believe the approved fix for this is to install ball, of a larger diamiter.
Old August 26th 13, 10:20 AM posted to rec.aviation.soaring
Eric Munk
Same here. Replaced the worn balls with ones of larger diameter on several
gliders. Easy fix, works very well. Parts available through TC-holder.
diamite=
r.
I'll check on that. They are available.=20
The idea of installing thin shims does not work on Grobs. The attachment
is=
quite different than other gliders.
Roberet Mudd
Composite Aircraft Repair
Parts and service for Grob gliders and motorgliders=20
Moriarty NM=20
there=
approachin=
g The paperwork I had as far as I recall was from Grob to the UK air
cadets=
p=
laced onto the wing spigots to take up wear. In "little balls" At 12:41
25
August 2013, JJ Sinclair wrote: On Sunday, August 25, 2013 3:57:26 AM
UTC-=
7, Astir. wrote: Has anyone got any definitive documentation regarding
t=
he fitting of "thin" shims on Astir wing spigots that are
approachin=
g the 5mm limit on collars I recall having something a few years
ago,=
but unable to retrieve it Fully aware of the engineering logic of
to=
o thick shims and ball/spigot relationship Are you saying that
the=
bottom
fusela=
LS1 Tail locking spring Andrew[_9_] Soaring 7 September 24th 10 02:09 AM
Winpilot pro and Ipaq 4700 locking up. joesimmers Soaring 5 July 17th 08 05:42 AM
90 degree locking pliers? B. Jensen Home Built 8 October 3rd 05 06:50 PM
New Wheel Locking Device TM Products 2 March 29th 05 04:07 PM
Looking for 3/8 in-24 thread/low profile self locking nuts/ Larry Home Built 3 February 22nd 05 03:02 PM
