Dittel FSG 71 M Help
Old October 24th 13, 01:44 AM posted to rec.aviation.soaring
Nick Kennedy
Default Dittel FSG 71 M Help
Hi Gents
Can anyone give me some help advice with my radio please.
On the ground it transmits fine, but will not receive.
Once in the air, like on tow and the rest of the flight it is 5x5, both
transmitting and receiving. Crystal clear with huge range.
What is going on?
Old October 24th 13, 02:30 AM posted to rec.aviation.soaring
On Wednesday, October 23, 2013 7:44:55 PM UTC-5, dogger wrote:
Tim at Wings and Wheels helped me out. Give him a call.
S9
Old October 24th 13, 03:06 AM posted to rec.aviation.soaring
Dave Springford
What is going on?
Are you parked close to a transformer and/or power lines when you are on the ground? This often interferes with the radio.
Old October 24th 13, 03:32 AM posted to rec.aviation.soaring
Nick Kennedy
At 02:06 24 October 2013, Dave Springford wrote:
What is going on?
No I'm out on a large open ramp when it won't receive.
Old October 24th 13, 04:38 PM posted to rec.aviation.soaring
Read my FSG71M write-up in the link below.
https://sites.google.com/site/threeu.../dittel-fsg71m
On mine the audio relay became pressure sensitive (fine on the ground, going bad in the air).
Someone else had the same problem and also fixed it by the procedure I described.
The audio relay is not available anymore from the supplier.
Old October 26th 13, 09:33 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Nick Kennedy wrote, On 10/23/2013 7:32 PM:
What is going on?
Does it have a "receive" indicator, like an "RX" symbol that flashes on
the display? Can you adjust the squelch to get the hiss?
email me)
Old November 8th 13, 11:25 AM posted to rec.aviation.soaring
ChrisChav
Le jeudi 24 octobre 2013 17:38:27 UTC+2, a écrit*:
Hello,
I flew in France and I have exactly the same pb with my same radio model.
Please can you tell me what relay you used to replace the failed relay (supplier, type, number, ...)
Thank you in advance
gliding greetings
Old November 8th 13, 07:22 PM posted to rec.aviation.soaring
responded to Christian off-line.
Dittel FSG 50 in Dittel base station [email protected] Soaring 2 February 18th 09 09:15 AM
Dittel FSG 50 in Dittel base station, Perfect for crews and FBO [email protected] Soaring 1 February 18th 09 09:15 AM
Dittel ATR 720 John C Soaring 3 September 19th 06 05:30 PM
Dittel Joseph L. Hyde Soaring 2 July 12th 05 03:25 PM
Dittel FSG 15 A. Wolfert Soaring 0 December 18th 04 01:14 PM
