Terminal Strip with Integral fuse
Old October 31st 13, 07:28 PM posted to rec.aviation.soaring
SF
Default Terminal Strip with Integral fuse
Terminal Strip with an integral mini blade style fuse.
www.asi-ez.com
Item: MF901GR, type MFPA.4 Screw clamp blade fuse terminal block gray.
Item: PTC0400, push in bridge for 6mm terminal blocks, 42 positions.
This terminal strip is larger than I really want it to be, but it is the smallest that I can find with integral fuses. Using integral fuses gives you an individual fuse on every load, lessens the number of connections, and reduces the behind the panel clutter.
You have to reach your own decision as to the suitability of this for your glider. I'm not suggesting it, I'm merely responding to a request on an earlier thread to report what I found. This does not replace the need for a fuse on every battery as close as possible to the battery terminals.
SF
Old October 31st 13, 11:32 PM posted to rec.aviation.soaring
Dave Nadler
Or these:
http://www.digikey.com/product-detai...697-ND/1645038
http://www.newark.com/jsp/search/browse.jsp?N=422+2203+200607+810319992&Ntk=gensear ch&Ntt=fuse+block&Ntx=mode+matchallpartial&display text=&isGoback=false&resultsPageURL=/jsp/search/results.jsp&isRedirect=false&No=0&getResults=true& appliedparametrics=true&locale=en_US&divisionLocal e=en_US&catalogId=&skipManufacturer=false&skipPara metricAttributeId=&prevNValues=422+2203+200607+810 319992+810446101&mm=1001318||,&filtersHidden=false &appliedHidden=false&autoApply=false&originalQuery URL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D422%2B2203% 2B200607%26Ntk%3Dgensearch%26Ntt%3Dfuse%2Bblock%26 Ntx%3Dmode%2Bmatchallpartial%26displaytext%3D%26is Goback%3Dfalse%26resultsPageURL%3D%2Fjsp%2Fsearch% 2Fresults.jsp%26isRedirect%3Dfalse%26No%3D0%26getR esults%3Dtrue%26appliedparametrics%3Dtrue%26locale %3Den_US%26divisionLocale%3Den_US%26catalogId%3D%2 6skipManufacturer%3Dfalse%26skipParametricAttribut eId%3D%26prevNValues%3D422%2B2203%2B200607
Old November 1st 13, 12:31 AM posted to rec.aviation.soaring
Papa3[_2_]
I really like these:
http://www.powerwerx.com/powerpole-p...orizontal.html
www.asi-ez.com
SF
Old November 1st 13, 08:05 AM posted to rec.aviation.soaring
On Friday, November 1, 2013 12:32:40 AM UTC+1, Dave Nadler wrote:
Or these:
I have the second one lying around at home, looks good but it's pretty heavy.
Old November 2nd 13, 04:42 AM posted to rec.aviation.soaring
[email protected][_1_]
+ 1 for Powerwerks RigRunner. Only downside is that it is a bit large. Other than that, a fantastic power distribution device.
Old November 4th 13, 05:01 PM posted to rec.aviation.soaring
The PC-8 from Eastern Beaver looks perfect. 8 ATM mini fused ports so you can start at 1 amp and go up. A bridge can be used from battery to PWR terminals so all 8 fuses are un-switched. I have not had one in my hands but intend to update over the winter.
http://www.easternbeaver.com/Main/Wi...8.html#pc8only
Old November 5th 13, 07:27 PM posted to rec.aviation.soaring
SF
Guys, what I'm using is a small terminal strip with an integral fuse, not these honking big fuse blocks you guys are coming up with.
https://www.asi-ez.com/pix/doc/mf100gr.pdf#view=fitv
B40 fuse question Tuno Soaring 3 December 8th 08 07:43 PM
Antifreeze that is safe with integral water ballast tanks Tim Taylor Soaring 7 October 14th 07 05:15 AM
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
ballasting with integral tanks Flavio Formosa Soaring 4 September 21st 04 10:17 PM
Restoring an Old Spam Can -- To Strip or Not to Strip jls Home Built 21 July 21st 04 09:39 PM
