SN10b data to PNA?
Old November 10th 13, 05:14 PM posted to rec.aviation.soaring
Default SN10b data to PNA?
Looking for advice on how to send data from an ILEC SN10b to a pna device such as an Avier/Gliderguider etc.
Thanks for any help.
Mark
Old November 10th 13, 09:27 PM posted to rec.aviation.soaring
Dave Nadler
Mark
Connect SN10 NMEA output (RS232) to PDA input.
SN10 NMEA output is also connected for example
to FLARM input for task declaration.
Do **NOT** connect PDA output to SN10 !!
Check SN10 option "PDA" to enable output.
NOTE: PDA must use proper RS232 levels or you will have a small fire.
Hope that helps,
Old November 11th 13, 12:23 AM posted to rec.aviation.soaring
I suggest a professional cable such as available from Craggy Aero he http://www.craggyaero.com/cables_connection_kits.htm . These can connect your GPS - SN10 - PNA. Evan being a fairly proficient engineer, my decision to buy one of these was worth the money many times over. When GPS & PNA things aren't working correctly, it's nice to know it's not your home made cable, so you only have to figure out what menu setting you have wrong. If in doubt, call Richard.
ILEC SN10B [email protected] Soaring 5 August 28th 13 10:55 PM
Looking for used SN10B yankeegolf Soaring 0 March 15th 10 12:21 PM
SN10B for sale Dick[_3_] Soaring 0 June 6th 09 09:05 PM
SeeYou Mobile with SN10B data kirk.stant Soaring 30 October 31st 08 08:01 PM
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 05:06 PM
