ASG-28 W&B Excel Template
Old November 11th 13, 03:32 PM posted to rec.aviation.soaring
Tom K (TK)
Default ASG-28 W&B Excel Template
Does anyone have a good excel W&B template for a ASG-29?
Thanks!
Old November 12th 13, 08:15 AM posted to rec.aviation.soaring
Thanks!
I don't know if it's "good" (but assume so), but there is one in the ASW-27 and ASG-29 owners group on yahoo.
Old November 12th 13, 06:32 PM posted to rec.aviation.soaring
Thanks!
I built a spreadsheet to do the W&B on my -27, but also use an app that is a lot more capable:
http://www.glideplan.com/seeg_stuff/info_seeg.html
Generally people measure the moment arms themselves rather than assuming that every example of a particular make/model is identical, though theoretically I guess they should be pretty close. The weights are another matter - you can't assume any two are the same, therefore you have to start with an initial measuring of the main and tail moment arms and weights. If you are looking at the effect of adding and subtracting equipment maybe someone else's moment arm measurements will be good, maybe not. Best to double check.
9B
Discus B instrument panel template [email protected] Soaring 11 November 5th 17 01:01 AM
Drilling Template. Darek Soaring 7 November 23rd 09 08:13 PM
Hole template or Drawing for Altimeter Craggy Aero Home Built 5 November 15th 07 02:40 PM
3 1/8" instrument template [email protected] Home Built 4 April 15th 06 02:26 AM
LS3 flaperon gap seal template needed Birdbones Soaring 2 May 14th 05 12:46 AM
