GPS to ELT?
Old November 13th 13, 06:50 PM posted to rec.aviation.soaring
Default GPS to ELT?
So if you have an ELT that broadcasts GPS such as the ACK-A-30-4, what is the best way to get 9400 baud to the GPS?
Old November 14th 13, 07:16 PM posted to rec.aviation.soaring
Paul Remde
Default GPS to ELT?
Hi,
I'm sorry, but your question doesn't make sense to me. You set the GPS baud
rate to 9600, or you set the jumpers in the ACK ELT to use whatever baud
rate your GPS uses. I sell a standard cable with GPS status light that
works great with the E-04 ELT.
http://www.cumulus-soaring.com/ack.h...9m-LED-12V-0.3
I have configured customer systems using a Garmin GPS 16x-HVS GPS. It
worked very nice.
However, ELTs aren't selling very well lately. Most sailplane pilots seem
to prefer SPOT or inReach units - myself included.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_______________________________________
Old November 15th 13, 12:10 AM posted to rec.aviation.soaring
darrylr
Default GPS to ELT?
Ah an ACK A-30 is an altitude encoder not an ELT. Your ELT install documentation should make all this clear. If its an ACK ELT it will take common garden variety inputs from lots of sources, including some you likely have already in your cockpit.
Old November 15th 13, 05:48 PM posted to rec.aviation.soaring
Default GPS to ELT?
My bad...got the models mixed up...lets start over. The correct model is ACK E-04 ELT. I guess the question comes down to is it better to provide dedicated GPS using something like a Garimin GPS 16 or split the GPS signal using the K6 Mux 2?
