FAA to use BMI to trigger screening for Sleep Apnea
Old November 23rd 13, 04:04 PM posted to rec.aviation.soaring
son_of_flubber
Default FAA to use BMI to trigger screening for Sleep Apnea
BMI (Body Mass Index) is a number calculated from your height and weight.
On the logic that pilots with BMI over 40 are likely to have Sleep Apnea and therefore more likely to fall asleep when piloting, the FAA is planning to require AMEs to use BMI to trigger evaluation for sleep apnea when airmen seek medical certificate.
http://www.npr.org/blogs/thetwo-way/...ts-controllers
This is unlikely to have immediate practical impact on soaring because most people with a BMI of 40 will be too heavy to fly a glider. But the threshold might later be lowered to 30 because Sleep Apnea is very common for people with BMI over 30. (BMI 30 is the threshold for obese classification).
A person who is 5'-8" would need to weigh 262 lbs to have BMI = 40.
A person who is 5'-8" would need to weight 197 lbs to have a BMI = 30.
Calculate your BMI (Body Mass Index) he http://www.nhlbi.nih.gov/guidelines/...MI/bmicalc.htm
Most of us know that BMI unfairly classifies some healthy body types (like weight lifters) as obese, but that discussion is old and boring. BMI shortcomings do not stop the FAA from using BMI as a trigger for screening.
Old November 24th 13, 03:02 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Right now this is only a proposed requirement. They have not decided if they are going to use it yet.
This is unlikely to have immediate practical impact on soaring because most people with a BMI of 40 will be too heavy to fly a glider. But the threshold might later be lowered to 30 because Sleep Apnea is very common for people with BMI over 30. (BMI 30 is the threshold for obese classification)..
Old November 24th 13, 04:47 PM posted to rec.aviation.soaring
son_of_flubber
"The purpose
of this editorial is to alert you to a policy that we will be
releasing shortly on obstructive sleep apnea (OSA)."
Source: https://www.faa.gov/other_visit/avia...dia/201304.pdf
Old November 25th 13, 02:40 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Like I said, a proposal. There is going to a lot of discussion before this is ever gets put into force.
"The purpose
Old November 24th 13, 06:44 PM posted to rec.aviation.soaring
Roy Clark, \B6\
A recent review of the overall risks of different BMI levels:
Random-effects summary all-cause mortality HRs for overweight (BMI of 25-30), obesity (BMI of ≥30), grade 1 obesity (BMI of 30-35), and grades 2 and 3 obesity (BMI of ≥35) were calculated relative to normal weight (BMI of 18.5-25).
Relative to normal weight, both obesity (all grades) and grades 2 and 3 obesity were associated with significantly higher all-cause mortality. Grade 1 obesity overall was not associated with higher mortality, and overweight was associated with significantly lower all-cause mortality. The use of predefined standard BMI groupings can facilitate between-study comparisons.
Flegal KM, Kit BK, Orpana H, Graubard BI.Association of all-cause mortality with overweight and obesity using standard body mass index categories: a systematic review and meta-analysis. JAMA. 2013 Jan 2;309(1):71-82. doi: 10.1001/jama.2012.113905.
Can help you assess your own risk.
Old November 24th 13, 11:20 PM posted to rec.aviation.soaring
Craig R.
Considering that any Mr. Olympia or Mr. Universe bodybuilder would be grossly obese using BMI, perhaps a different and more accurate measurement scale would be in order...
Old November 25th 13, 12:47 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
They're still hunting around for the manufacturer's approved data....
T8
airline security screening Jim Macklin Piloting 0 August 25th 06 11:47 AM
Sleep Aid and Medical Question Flyin'[email protected] Piloting 15 April 7th 06 02:40 AM
FAA Medical and pilots with Sleep Apnea Chuck Owning 20 October 2nd 05 02:09 AM
Identifying an Aircraft Firing Trigger Mechanism Tasp Military Aviation 3 August 13th 04 07:40 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
