Linear Actuators on Trailer
Old November 27th 13, 05:46 PM posted to rec.aviation.soaring
Default Linear Actuators on Trailer
Has anyone used 12v electro-mechanical/12v electro-hydraulic/manual hydraulic linear actuators on a clam shell/alligator type trailer top. I have bent 4 (SUSPA) gas springs in the past 4 months. Ordered what was on the trailer when purchased. Ordered a pair of Bansbach Easylift gas springs, but waiting for the SUSPA gas springs currently on the trailer to fail before I put the new ones on.
If you have done any type of linear actuators and it is working, can you forward photos? If tried and it is a futile effort on my part let me know, I would prefer to spend my funds on other glider stuff.
r/Jim
N9XL/H201B
Old November 27th 13, 07:05 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Are they bending when extended or retracted? Check on the mechanism to make sure you aren't getting something nearly on center when open. If you go there, loads go out of sight high, and you can bend things when you try to move it back the other way.
Steve Leonard
Old November 27th 13, 08:41 PM posted to rec.aviation.soaring
Steve Leonard
They bend when bringing the top down. They bend to the back of the trailer.
The trailer weighs in at 1200lbs. sq tube truss construction covered in aluminum sheeting. suspect from the size of the top it weighs in at a good 600lbs+.
Old November 27th 13, 11:32 PM posted to rec.aviation.soaring
Dan Marotta
I'm not a mechanical engineer, but I've seen lift struts encased in square
tubing. There are two square tubes, sized to slide into each other. They
are attached to the pivots on the top and bottom of the trailer using the
same bolts that attach the gas strut to the trailer.
It would appear that the square tubing would support the gas struts and
prevent or reduce the tendency to bend.
But, then again, I'm not a mechanical engineer.
Steve Leonard
trailer.
good 600lbs+.
Old November 27th 13, 11:37 PM posted to rec.aviation.soaring
Dan Marotta
Something like this?
http://www.servocity.com/html/560_lb...r_actuato.html
Don't know your stroke length requirement, but these guys may be able to
custom build what you're looking for. PS - They ain't cheap!
r/Jim
N9XL/H201B
Old November 28th 13, 12:54 PM posted to rec.aviation.soaring
GM
r/Jim
N9XL/H201B
Jim,
when a long slender member like a cylinder or gas spring bends or buckles, it is a clear indication of side-loading. There are several ways of introducing side loading, such as the member's own weight (not likely in your case), the member interfering with something during its operation (you would have seen that already) or due to torque introduced into the pivot points. Please check if both rod ends are free to swivel, i.e. have either a straight bushing or better yet a spherical eye end. The bolt or pin going through said bearing must not bind the rod or body end of the gas spring.
The nesting square tubing Dan M. mentioned are more for protection and guidance of the shell and they may limit the sway of the shell as it moves up and down. Are you seeing this damage on an Eberle trailer which many Std.Libelles came in?
Uli
Old November 28th 13, 02:40 PM posted to rec.aviation.soaring
Dave Nadler
Jim - Take some photos of the trailer top lift
mechanism in the closed and open positions and
post them, otherwise we're all guessing here.
Forget about linear actuators!
Happy Thanksgiving,
Old November 28th 13, 03:56 PM posted to rec.aviation.soaring
Dan Marotta
Yah, but wouldn't it be great to push a button, take a sip of your beer, and
watch the lid open/close? The tail gate on my car does that (by wireless!)
and it's very nice!
"Dave Nadler" wrote in message
Happy Thanksgiving,
Old November 28th 13, 06:02 PM posted to rec.aviation.soaring
Dave Nadler
and watch the lid open/close?
Sure, until only one side operates.
Then again, I'm still frightened by my new car...
Much simpler to fix the original mechanical problem,
though no doubt less entertaining.
Old November 29th 13, 05:24 PM posted to rec.aviation.soaring
Dan Marotta
A second beer will alleviate worries about single-sided failures...
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
How well does linear polyurethane paint hold up to flying in wave and sunlight? son_of_flubber Soaring 0 October 1st 12 01:52 AM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
FS:CS-10 VHF communications linear amplifier RPE Home Built 2 January 17th 07 05:30 PM
FS Communications Specialist CS-10 Linear amplifier RPE Aviation Marketplace 1 January 3rd 07 03:08 AM
