Good afternoon all.
	Im seriously contemplating beginning an aerobatics endorsement. I have been flying for 2 years and want to "add". I have done plenty of research and have narrowed it down to a number of aeroplanes: The Zlin (sp?) The Citabria The Cessna aerobat. I know the Decathlon and Zlin are faster and more manueverable but they are also significantly more expensive for lessons (and I dont like the idea of learning to fly a tailwheel unless its essential). Question is, does the Cessna provide enough enjoyment ( I know it loops, but...) or is it really a Clayton's aerobatics aircraft. Basically, will I have enough fun in it to get by? Im interested in those whove flown some of these and what their thoughts were. Thanks and regards, AH.  |
Assuming you're in the US, there's no such thing as an aerobatic
	endorsement. Believe it or not, the day you get your PPL you can go out and tailslide into an inverted flat spin in complete, if evanescent, legality. (Well, there's always 91.13, but I guess that if you make it back it wasn't reckless). That said, it would be pretty dumb, indeed it would be extremely dumb to even try acro without an experienced acro instructor beside/behind you. The most important thing is to find the right instructor - good acro instructors are fairly rare, I'm extremely lucky to have found one locally. If you can find one, go for it - it's tremendous fun and extremely satisfying. Don't be surprised if you can't do it for very long at a time. I've done acro in a Decathlon and a Grob. The Grob was OK (apart from the ever-present smell of avgas, which is a known problem with them), the Decathlon is MUCH more fun. I plan to try a Pitts and/or Extra this summer. I've not flown the Aerobat (although my school has one). For the basics, anything will be fine. A constant-speed prop makes things MUCH easier though as you essentially don't touch the power which means (a) a lot less messing around at times when you're pretty busy anyway and (b) you lose less altitude in the manouvers. I can get a lot more done in the Decathlon than in the Grob simply because I spend almost no time climbing - I climb to 6000' on my way to the practice area, by the time I'm done I'm down to about 4000', having expressly climbed maybe a couple of times. If I have any altitude left at the end I spin it off which is good practice. The tailwheel thing (which IS an endorsement) is kind of a pain, especially wheel landings, but an awful lot of fun planes are taildraggers so it's more when than if, imo. The Citabria (and Decathlon) is especially fiendish because of the bounce-o-matic spring steel gear. My advice is, get started in the Aerobat, but expect to transition to something faster (forwards and rotationally) once you've mastered the basics. John "Anthony Hewitt." wrote in message ... Good afternoon all. Im seriously contemplating beginning an aerobatics endorsement. I have been flying for 2 years and want to "add". I have done plenty of research and have narrowed it down to a number of aeroplanes: The Zlin (sp?) The Citabria The Cessna aerobat. I know the Decathlon and Zlin are faster and more manueverable but they are also significantly more expensive for lessons (and I dont like the idea of learning to fly a tailwheel unless its essential). Question is, does the Cessna provide enough enjoyment ( I know it loops, but...) or is it really a Clayton's aerobatics aircraft. Basically, will I have enough fun in it to get by? Im interested in those whove flown some of these and what their thoughts were. Thanks and regards, AH.  |
"John Harper"  wrote in message
	news:1083122620.771235@sj-nntpcache-5... Assuming you're in the US, there's no such thing as an aerobatic endorsement. Assuming the origin of his post is any indication, he's from Australia. Maybe they do have an aerobatic endorsement?  |
			 My recommendation... Begin in a 108 hp Citabria (if available) the low powered aircraft will teach you more about proper control input) Move up to a fixed pitch 150 hp Decathlon this gives you a symetrical wing (heavier control inputs) and a little more hp to work with. Next step is the 180 hp, constant speed prop, Super Decathlon this aircraft will take you up through Intermediate and some of the Advanced competion maneuvers. After you have mastered the Super Decathlon, you will have sufficient experience to handle most of the high performance acro mounts.  |
In article 1083122620.771235@sj-nntpcache-5, John Harper
	wrote: The tailwheel thing (which IS an endorsement) is kind of a pain, especially wheel landings, but an awful lot of fun planes are taildraggers so it's more when than if, imo. The Citabria (and Decathlon) is especially fiendish because of the bounce-o-matic spring steel gear. If you had an instructor who knows the aircraft, they would have taught you the proper way to land the Citabria/Decathlon without bouncing, be it a wheel landing or three-point. Airspeed control and pitch attitude determine your rate of descent. With wheel landings, the pitch attitude is flat or slightly tail low, you land at flying speed, which gives you a slow rate of descent, the wheels will roll on with increasing forward stick pressure as you reduce throttle. Some people will tell you to "pop" the stick forward when the wheels make contact to keep them planted. For three-point landings, too fast and you float, just like with a tricycle gear aircraft. Too slow, your pitch attitude and sink rate will be too high. At the roundout, pitch attitude should be the same as when you are sitting on the ground. On airspeed, you will arrive at the threshhold at this attitude, just above stall, the wheels will gently settle onto the surface.  |
yep certainly does require an endorsement in Oz.
	"Peter Duniho" wrote in message ... "John Harper" wrote in message news:1083122620.771235@sj-nntpcache-5... Assuming you're in the US, there's no such thing as an aerobatic endorsement. Assuming the origin of his post is any indication, he's from Australia. Maybe they do have an aerobatic endorsement?  |
Anthony,
	You might want to go to AVweb (www.avweb.com), then click on "columns", then on "The Pilot's Lounge" and scroll down to the column on aerobatics. It has a discussion of the more common sorts of akro trainers. Any of the ones you named will work just fine. It doesn't matter as to the type of airplane in which you take your initial training. The smaller, lower powered ones will require more work on your part, but you will be able to handle anything after that. All the best, Rick "Anthony Hewitt." wrote in message u... Good afternoon all. Im seriously contemplating beginning an aerobatics endorsement. I have been flying for 2 years and want to "add". I have done plenty of research and have narrowed it down to a number of aeroplanes: The Zlin (sp?) The Citabria The Cessna aerobat. I know the Decathlon and Zlin are faster and more manueverable but they are also significantly more expensive for lessons (and I dont like the idea of learning to fly a tailwheel unless its essential). Question is, does the Cessna provide enough enjoyment ( I know it loops, but...) or is it really a Clayton's aerobatics aircraft. Basically, will I have enough fun in it to get by? Im interested in those whove flown some of these and what their thoughts were. Thanks and regards, AH.  |
A
	Here's my opinion, for what it's worth. Let's start with the tailwheel thing. Absolutely learn to fly one. In my opinion, every pilot should start learning in a tailwheel airplane without an electrical system and at a grass strip. That's real stick and rudder flying and that's where you really learn how to maneuver an airplane. The rest is just junk added on. If you don't take the time to master a taildragger, nearly all worthwhile aerobatic aircraft will be forever out of your reach. Not only will it teach you excellent flying skills, taildragger flying is a hell of a lot of fun, usually involves interesting airplanes, and gives you an immense sense of satisfaction. It may be more expensive but you'll never regret the skills, the experience, or the horizons it opens up for you. I've been flying tailwheel airplanes for over 5 years now and haven't been in anything with a nosewheel since. As for the types you mentioned, I'm by no means an expert on the Citabria or the Zlin. I do know that the Zlin was a top of the line aerobatic competition aircraft in it's day and still has a good reputation as a performance machine. Both it and the Citabria were designed for aerobatics specifically. The C152 wasn't. It's a basic trainer with some mods (and don't ask me what they are) to increase it's load capability. I wouldn't waste my time with a 152. There are others that disagree, saying "if you can aerobat and Aerobat, you can aerobat anything", and they may be right, but I never bothered. It's roll rate is pedestrian in the extreme, it can perform vertically for about it's own length, and it's a right bugger to spin and keep spinning. I think you'd quickly find the aerobat either limiting or frustrating. My own progression was 125 hours in 152s, including PPL training 10 hours Tailwheel training in a SuperDecathalon (loads of fun, first loop and roll, too!) 150 hours in Cubs and Taylorcraft (which is where I really learned to fly) 75 hours in a Pitts S-1D With that much tailwheel time (most of it spent maneuvering in all conditions in the pattern), transition to the Pitts was a piece of cake. That's when I started my aerobatic training, took a few lessons from international competition pilots, asked a lot of questions of experts, climbed to 5,000 feet and tried a few things out. Haven't scared myself yet (except once in the 152 as a student!), but I know my limits and I stay very far away from them. As always, your mileage may vary, but that's my advice. Of course, the quality of the instruction that comes with each of these airplanes you mentioned will be a major factor as well. Good luck and let us know how you get on! Shawn "Anthony Hewitt." wrote in message ... Good afternoon all. Im seriously contemplating beginning an aerobatics endorsement. I have been flying for 2 years and want to "add". I have done plenty of research and have narrowed it down to a number of aeroplanes: The Zlin (sp?) The Citabria The Cessna aerobat. I know the Decathlon and Zlin are faster and more manueverable but they are also significantly more expensive for lessons (and I dont like the idea of learning to fly a tailwheel unless its essential). Question is, does the Cessna provide enough enjoyment ( I know it loops, but...) or is it really a Clayton's aerobatics aircraft. Basically, will I have enough fun in it to get by? Im interested in those whove flown some of these and what their thoughts were. Thanks and regards, AH.  |
| Thread Tools | |
| Display Modes | |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | February 1st 04 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 07:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 07:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 08:27 AM |
