Wingstands Update
Old January 16th 14, 12:35 AM posted to rec.aviation.soaring
Papa3[_2_]
Default Wingstands Update
Hi,
Anyone have any thoughts on the current state of the art for light, compact wingstands. I've reviewed all of the threads from the last few years as well as looking at various websites. Just wondering if there are any new entrants to the market.
FWIW, I absolutely LOVE the old Wings and Wheels wingstand from the early 2000s that came in kit form. Cheap, light, simple, and incredibly robust. I could probably see fabricating and powdercoating the two key parts (top cluster and the leg support unit) if I had the time... which I don't. If anyone wants to sell a used one (or two) I'd be interested.
P3
Old January 16th 14, 03:12 AM posted to rec.aviation.soaring
6PK
On Wednesday, January 15, 2014 4:35:47 PM UTC-8, Papa3 wrote:
Hi,
Simple, sturdy, light, inexpensive and readily available at any Home Depot
http://www.homedepot.com/p/RIDGID-Fl...934/100618242#
Old January 16th 14, 03:40 AM posted to rec.aviation.soaring
Paul Remde
Hi,
That Home Depot stand does look like a good option. Has anyone used one as
a wing-stand?
Paul Remde
______________________________
"6PK" wrote in message
Hi,
Old January 16th 14, 04:06 AM posted to rec.aviation.soaring
6PK
On Wednesday, January 15, 2014 7:40:48 PM UTC-8, Paul Remde wrote:
Hi,
a wing-stand?
Paul Remde
Hi,
Several guys at CalCity including myself for several years now. Not a one problem.
6PK
Old January 16th 14, 05:24 AM posted to rec.aviation.soaring
Frank Whiteley
Hi,
a wing-stand?
Paul Remde
Hi,
6PK
I had the tightening handle on the vertical adjust clamp break on one. Otherwise no other issues.
Frank Whiteley
Old January 16th 14, 05:55 PM posted to rec.aviation.soaring
Papa3[_2_]
I've seen a bunch of them around. My main objection is that they don't fold down nearly as small as the old Wings and Wheels design. You could fit two of the W&W wingstands in an 8" ID tube for storage (i.e. a length of PVC pipe). With all of the crap that starts to end up in our trailers, compact breakdown is important (at least to me).
P3
Old January 16th 14, 05:53 AM posted to rec.aviation.soaring
I use one and so does another club member. Because I like having a "redundant back-up to critical systems" I drilled three holes in the sliding upright and have a tethered locking pin to insert in them to back up the friction clamp. We both made contoured foam pads for the top plate which fit nicely into the contours of the wing underside. This holds the wing nice and steady during rigging. I actually like it better than the genuine Cobra wingstand the club 505 has.
I've also used the same stand with the club Twin Astir. If it can hold one of those solid concrete wings steadily a 15 meter ship is a breeze!
Old January 16th 14, 07:51 AM posted to rec.aviation.soaring
Tim Taylor
My favorite is still the Pearl C900 Cymbal stands. Has that perfect feel of quality and are flexible in height.
TT
Old January 16th 14, 09:00 AM posted to rec.aviation.soaring
Peter Scholz[_3_]
Am 16.01.2014 01:35, Papa3 wrote:
Hi,
P3
Another alternative ist this type:
http://www.homedepot.com/p/Workforce...C43/202530462#
I use two of those since several years. Lightweight, durable, easy to
store.
I took off the top roller and replaced it with a piece of suitable foam
insulation for heating pipes. Also reinforced the thread for the fixing
clamp when it became worn out, since then no problem at all. I use it
during assemply as well as for supporting the wings during tie-down when
leaving the plane assembled overnight.
Peter Scholz
ASW24 JE
Old January 16th 14, 04:06 PM posted to rec.aviation.soaring
Richard[_9_]
Hi,
P3
store.
Peter Scholz
ASW24 JE
Another good one from HomeDepot just cover with felt, rubber or carpet.
Richard
Craggy Aero LLC
Aug 29 Update DHeitm8612 General Aviation 0 August 27th 04 01:34 AM
Dec 14 Update DHeitm8612 General Aviation 0 December 12th 03 03:42 AM
Dec 7 Update DHeitm8612 General Aviation 0 December 5th 03 03:22 AM
Nov 16 Update DHeitm8612 General Aviation 0 November 14th 03 04:39 AM
Nov 9 Update DHeitm8612 General Aviation 0 November 7th 03 05:32 AM
