Experience with TRT800H-OLED Transponder?
Old January 28th 14, 04:20 AM posted to rec.aviation.soaring
NG
Default Experience with TRT800H-OLED Transponder?
Does anybody have experience with the TRT800H-OLED? Best pricing appears to be $2395.00. It is a self-contained (built in altitude encoder), Mode S, with flip-flop input and an apparently bright LED display. Looks perfect for gliders.
NG
Old January 28th 14, 05:30 PM posted to rec.aviation.soaring
Dan Marotta
Compare it to the Trig TT21 and decide. I have a TT22 but it costs more.
"NG" wrote in message
NG
Dan Marotta
NG
Old January 29th 14, 07:30 AM posted to rec.aviation.soaring
CJ[_3_]
For an extra $100-150, why wouldn't you?
Love the Trig, could find no better. The remote control head mounts in a
57mm hole and allows the box to be mounted where it suits YOU.
Casey Jay
B3
NG
Old January 29th 14, 11:45 AM posted to rec.aviation.soaring
Eric Munk
It is quite good. Have fitted it to about 15 gliders.
Old January 29th 14, 05:03 PM posted to rec.aviation.soaring
Eric, are you referring to the Trig or Funkwerk transponder? The TRT800H is currently being installed in the Aerotrek Light Sport aircraft here in the US. I'd also like to know if any glider guys are flying with the Funkwerk unit. Being fully integrated makes it very appealing. The only issue I'm aware of is that the unit boots up in standby mode which isn't a big deal unless you don't switch modes before launching. I like the flip-flop frequency setting toggle feature along with the bright OLED display.
Old January 29th 14, 11:44 PM posted to rec.aviation.soaring
Dan Marotta
My TT22 by Trig is also fully integrated - the radio and encoder are in a
remote box which is mounted under the floor of my LAK-17a. The control head
is, of course, mounted in my panel.
Flip-flop transponder frequencies are not a big deal in gliders since we
don't do a lot of ATC work (at least, not where I fly). Should I decide to
contact ATC and am given a separate transponder code, it's simple to dial it
in. When I cancel service, I simply press the "VFR" button, and my
transponder resets to 1202 (gliders).
This is thread is the first time I've heard about the TRT800H. Compare
power requirements, power output, installation and space requirements,
price, and decide which works best for you. I couldn't be happier with my
Trig!
A new experience Andy[_1_] Soaring 12 January 13th 11 07:48 PM
Better cockpit cameras - wide angle and OLED screen Eric Greenwell Soaring 6 June 6th 10 03:36 AM
Well that was an experience! es330td Piloting 0 July 31st 09 05:21 AM
Transponder vs. Portable Transponder Detectors John Murphy Soaring 16 December 20th 08 07:25 AM
Experience with AFS? Michael Horowitz Home Built 4 May 7th 07 09:15 PM
