Flight Computer Input Devices
Old February 25th 14, 04:10 PM posted to rec.aviation.soaring
Mike the Strike
Default Flight Computer Input Devices
I'm about to upgrade my Discus 2 panel with a more modern flight computer (5.6" class 640x480 display) and in reviewing the various options I am interested in user opinions about input devices.
My panel is just out of easy reach, so I'll need some input device - either stick-mount or cord-mount. Pros, cons and comments about the various approaches (button, trackball, etc.) would be useful.
Old February 25th 14, 04:32 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Mike the Strike wrote, On 2/25/2014 8:10 AM:
Don't mount it on the panel; instead, use a Ram mount or similar on the
panel to position it closer to you. I did that with an iPaq and a
ClearNav - easy (no changes required to the panel) and effective. Others
mount the display off the panel on the canopy frame (or just below the
frame), allowing the display to be within easy reach, or on a bracket
affixed to the glare shield.
email me)
Old February 25th 14, 06:18 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Beware any device that requires precision analog hand / eye coordination. It will add up to an awful lot of head in the cockpit time. A push button interface ("digital", not analog), stick mounted, works well for most pilots (and works great on ClearNav).
Evan Ludeman (affiliated with ClearNav, but speaking for myself)
Old February 25th 14, 08:49 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Evan Ludeman wrote, On 2/25/2014 10:18 AM:
"It depends" a lot on what your flying is like. I've used SeeYou Mobile
on an iPaq (600+ hours), and currently a ClearNav (600+ hours), and
found the touch interface to be quicker, easier, more intuitive, and
required less eye contact with the display.
If I flew on turbulent ridges routinely, perhaps I'd feel differently,
but the huge number of touch interface flight computers in use indicates
the efficacy of the method.
email me)
Old February 25th 14, 09:03 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
I'd make the argument that their numbers reflect the easy availability and economy of these consumer devices myself... but the important thing is that you have devices that work well for your use and *don't* require a lot of head in the cockpit time.
best,
Evan Ludeman
Old February 25th 14, 10:05 PM posted to rec.aviation.soaring
Papa3[_2_]
I'm with Evan on this (and yes, I'm also a ClearNav guy). I recently posted to a similar thread on our Appalachian Mountains Soaring Group, but to summarize:
- I nearly tossed a working IPAQ Aero 1520 out the apple core window into the Susquehanna River thanks to the frustrations of trying to poke at a touchscreen while moving along at 100kts in +/- 2G turbulence.
- All of the aircraft in high intensity environments use HOTAS (hands on throttle and stick) controls with various buttons and switches.
- Trackballs are miserable in an unstable environment like glider; impossible to point and click on the target; even worse than pointing your finger.
- You will quickly learn the patterns in a device with large buttons arranged on a remote (stick mounted or tethered). I can zoom in, zoom out, and select without ever having to look down.
So, I'm another vote for a well laid out, button-based remote. IIRC, someone recently demoed a primitive COTS solution using XC Soar or LK 8000 (one of the Android crew).
Erik Mann
P3
best,
Evan Ludeman
Old February 26th 14, 01:17 AM posted to rec.aviation.soaring
Craig Funston[_2_]
Erik Mann
P3
best,
Evan Ludeman
That was Paolo for LK8000 (Windows mobile based)
Craig
7Q
Old February 26th 14, 04:11 AM posted to rec.aviation.soaring
Richard[_9_]
Mike,
I have over 800 hours with a track ball mouse input. It work extremely well even in turbulence. The menu button on the Utlimate Le SeeYou are large and just about impossible to miss with a track ball mouse. The thumb trackball on the stick trigger works the best. And best of all you already know how to use it.
Richard
www.craggyaero.com
Old February 26th 14, 04:16 AM posted to rec.aviation.soaring
Richard[_9_]
Erik Mann
P3
best,
Evan Ludeman
Eric,
I am almost positive that you have never used a track ball in the cockpit. I have and find it works easily and is nothing like you describe, it is not miserable it is wonderful and easy to use.
Richard
www.craggyaero.com
Old February 27th 14, 07:17 PM posted to rec.aviation.soaring
waremark
Touch screens are best for land based activity, such as entering new tasks - no other system is as easy for entering text. I have used Winpilot and SYM for years on various devices and have not had problems hitting the right part of the screen in flight either, but I do not often fly at high speed in high turbulence.
Last season I was using an LX 9000. I have no difficulty reaching the controls on the panel. I find the use of rotary knobs for many tasks to be excellent, and much better than using sequential button pushes for the same tasks - so for me using the knobs on the instrument is much better than using buttons on the stick remotes (in the car I generally adjust my radio volume with the knob on the dash rather than the button on the steering wheel). BTW, I find the LX 9000 to be superb.
Zander ZS 1 Flight Computer [email protected] Soaring 1 July 28th 13 06:48 AM
Loading flight data to iPhone from serial port devices Craig Funston Soaring 5 July 25th 11 08:09 PM
Glider flight software on non PDA devices- soon. brianDG303 Soaring 23 November 19th 08 12:30 AM
Flight computer for Sale [email protected] Piloting 0 August 20th 05 06:12 PM
Zander 820 Flight COmputer Dave Kuchenbecker Soaring 0 May 7th 04 02:27 AM
