Calculating Polar in See You, Which Numbers?
Old March 4th 14, 08:01 PM posted to rec.aviation.soaring
Default Calculating Polar in See You, Which Numbers?
I am working on a new polar for my Silent-IN in See You. I have the data from Alisport, but the question that I have is which numbers to plug in to the See You Polar tool.
I have tried several different sets and get significantly different a. b. c. numbers in See You.
Any guidance on which pairs of numbers, speed plus sink rate would be helpful.
Min sink? Best L/D?, .............
After you use the tool, it defaults to 100, 120, 150 kph. This might be high for my lower performance bird.
Thanks
Kevin
Old March 5th 14, 04:12 AM posted to rec.aviation.soaring
Thanks
Kevin
Hi, Kevin,
don't go below the best l/d speed for your low number. Try putting together
a table of sink vs. speed in a spreadsheet, and calculate sink rate from a,b,c
and compare. Generally you'll do best with a low number around best l/d,
a high number around the fastest you'll fly, and the middle one in between.
I'll see if I can concoct a sample Google spreadsheet that shows how to do this.
Matt
Old March 5th 14, 08:47 AM posted to rec.aviation.soaring
Bryan Searle
to
helpful.
Thanks
Kevin
This is what I use for the Silent, using these Paul Remde tools:
http://www.cumulus-soaring.com/polars.htm
* LK8000 polar for: Silent2 Targa - 285kg AUW
* MassDryGross[kg], MaxWaterBallast[liters], Speed1[km/h], Sink1[m/s],
Speed2, Sink2, Speed3, Sink3, WingArea[m2]
285, 0, 92.0, -0.64, 146.0, -1.48, 200.0, -3.24, 8.9
* SEEYOU:
* 1.591
* -2.238
* 1.351
*Results from LK8000-V4 in simulate mode:
*Speed Efficiency Results Efficiency (Silent data)
* 90 39.6 40.0
* 95 39.6 39.6
* 100 39.9 38.5
* 105 39.7 37.5
* 110 39.2 37.0
* 115 37.8 36.5
* 120 37.0 35.0
* 125 35.0 34.0
* 130 34.0 33.0
* 135 31.9 32.0
* 140 30.9 30.0
* 145 28.9 28.5
* 150 27.0 27.0
* 155 26.1 26.5
* 160 25.3 25.0
* 165 24.4 24.0
* 170 22.9 22.0
* 175 21.5 21.5
* 180 20.6 20.0
Enjoy... Bryan
Old March 5th 14, 10:42 AM posted to rec.aviation.soaring
Thanks Matt,
Makes sense.
Kevin
Old March 5th 14, 10:44 AM posted to rec.aviation.soaring
Thanks Bryan,
I will look over what you have, but I am flying the little brother to your bird, 12 meter 31-1.
Kevin
Old March 5th 14, 10:53 AM posted to rec.aviation.soaring
Thanks Bryan,
Kevin
Here's my spreadsheet:
https://docs.google.com/spreadsheet/...Wc&usp=sharing
It calculates a, b, and c for you. Copy and paste it to your own
spreadsheet and you can play with the numbers.
Old March 6th 14, 02:02 AM posted to rec.aviation.soaring
dhaluza
You don't need to go below best L/D speed if all you want to do is cruise. But if you want to calculate netto, you will need the polar to be accurate at min sink too.
Thanks
Kevin
Hi, Kevin,
Matt
Polar numbers for Discus A Serge Serfaty Soaring 28 April 20th 16 04:39 PM
Calculating G Forces from IGC file? JohnDeRosa Soaring 8 March 15th 13 06:17 AM
Calculating Headwind/Tailwind component Ramy Soaring 13 March 15th 12 01:26 AM
Help calculating Speed To Fly for headwind and tailwind Tim Taylor Soaring 23 June 2nd 10 05:52 PM
Calculating CL for various wing shapes ian .at.bendigo Home Built 0 August 28th 03 12:47 PM
