Midwest Straight Soaring Season Underway!
Old March 12th 14, 07:25 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Midwest Straight Soaring Season Underway!
While not with as big a spalsh or fanfare as a Hugh and Gordo trek, KSA's Tony Condon (now changing over to The Cirrus Kid?) is off on a free distance run today. Cold front came blasting through yesterday afternoon, and with warm ground and cold air, thermals were predicted to be good. This, along with a good tailwind, makes long distance flights possible.
Tony departed from the Wellington airport at about 12:20 today. If you want to see how far he goes, you can watch the flight unfold he
http://share.findmespot.com/shared/f...08EyO4mMDp hc
Steve Leonard
Old March 12th 14, 07:52 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Midwest Straight Out Soaring Season Underway!
Oops. Straight Out. Can't edit the subject via google groups on the initial post, but I can on this one. Go figure.
Old March 12th 14, 08:29 PM posted to rec.aviation.soaring
Jim[_18_]
I've often seen cu fields that go from Kansas to the East Coast from the work plane and wondered if anybody was flying a long glider flight under them. Go Tony!
Jim Dingess
Old March 12th 14, 09:03 PM posted to rec.aviation.soaring
BobD
On Wednesday, March 12, 2014 2:25:08 PM UTC-5, Steve Leonard wrote:
While not with as big a spalsh or fanfare as a Hugh and Gordo trek...
Wichita to Paris! Just like Lindy! Er...Paris, Texas.
Old March 12th 14, 09:36 PM posted to rec.aviation.soaring
Steve Leonard
Looks like he is on the Kiamichi Ridge ! Is it possible to see his altitude ?
Old March 12th 14, 09:41 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Unfortunately, not with SPOT.
Old March 12th 14, 11:29 PM posted to rec.aviation.soaring
lynn
He has landed at De Queen, Arkansas at an airport.
Old March 12th 14, 11:42 PM posted to rec.aviation.soaring
Tony[_5_]
Had a nice long reply but its gone. Flight was pretty awesome and a good way to start then season. Took off as the first wisps arrived at wellington. First hour I took it really slow to let the clouds develop ahead of me and for most of the flight in didn't push real hard. Clouds ended at interstate 40 as forecast but a couple fires gave me confidence in the blue. They delivered and I found a few more good climbs in pure blue near McAlester which for me comfortably around my first turn point and onto the ridges. Ran up to Sardis Lake and then the familiar ole Kiamichi past Talihina.
Second turn point was Three Sticks on the Kiamichi with a goal of Texarkana.. DeQueen is about half way between. There was a nice thermal off the ridge and then in found another half way to DeQueen. Land out options are slim in this area so I took anything going up or holding zero for as long as I could.
Landed at DeQueen after 5.5 hrs. Dogleg distance is 317 miles. Straight line is 288 I think.
It was a great flight. KC and John are just leaving Talihina and should be here in a few hours.
Old March 13th 14, 09:31 AM posted to rec.aviation.soaring
Tony[_5_]
On Wednesday, March 12, 2014 6:42:04 PM UTC-5, Tony wrote:
Had a nice long reply but its gone. Flight was pretty awesome and a good way to start then season. Took off as the first wisps arrived at wellington.. First hour I took it really slow to let the clouds develop ahead of me and for most of the flight in didn't push real hard. Clouds ended at interstate 40 as forecast but a couple fires gave me confidence in the blue. They delivered and I found a few more good climbs in pure blue near McAlester which for me comfortably around my first turn point and onto the ridges. Ran up to Sardis Lake and then the familiar ole Kiamichi past Talihina.
Second turn point was Three Sticks on the Kiamichi with a goal of Texarkana. DeQueen is about half way between. There was a nice thermal off the ridge and then in found another half way to DeQueen. Land out options are slim in this area so I took anything going up or holding zero for as long as I could.
We made it home. Good morning RAS. Flight is up on the OLC: http://www.onlinecontest.org/olc-2.0...l?dsId=3486851
Old March 13th 14, 12:32 PM posted to rec.aviation.soaring
Luke Szczepaniak
Congratulations Tony, outstanding flight!
Luke
Start of New England soaring season! Dave Nadler Soaring 6 February 6th 14 11:15 PM
It's been a LOUSY U.S. soaring contest season! John Bojack[_2_] Soaring 14 June 19th 09 04:19 AM
Year Round Soaring in Tennessee - Season Never Ends MP Soaring 2 February 27th 09 02:58 AM
US midwest soaring nimbusgb Soaring 10 August 1st 07 08:59 PM
WGC Contest Day 3 Underway John Seaborn Soaring 0 June 8th 06 01:54 PM
