Glider pickup
Old May 30th 04, 01:01 AM
Morgans
Default Glider pickup
I was watching an old movie,"Objective, Burma!", circa 1945. At the end of
the movie, they picked up a glider, by hanging a rope on poles, then a C 47
went by with a hook, and snagged the rope, pulling the glider out, from a
dead stop, to flying. Was this a common maneuver?
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.690 / Virus Database: 451 - Release Date: 5/22/2004
Old May 30th 04, 01:27 AM
G.R. Patterson III
Yes.
George Patterson
None of us is as dumb as all of us.
Old May 30th 04, 11:00 AM
Cub Driver
It was really an extraction method, so I don't think it was commonly
used. (Individuals were yanked out the same way
Perhaps because of the high density altitude in India and Burma, it
became routine? Perhaps it did. Obviously a C-47 could more easily
heft the glider at 100? mph than it could on a takeoff run.
I wonder what kind of line they used? Manila doesn't have any stretch
in it! Was there nylon line in WWII?
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Old May 30th 04, 04:45 PM
G.R. Patterson III
It was used primarily to get things out of small clearings hacked out of jungle
areas. It was pioneered by groups like Wingate's Chindits. IIRC, it was Wingate's
idea.
Even for normal glider tows, the lines were coiled in such a way that the tow planes
had several hundred yards to gain speed and were off the ground before drag came on
the line. You can see film of this in "A Bridge Too Far."
Nylon was invented prior to the war, and women were very disappointed that nylon
stockings became nearly unavailable within a year after Pearl Harbor. The U.S. used
it for parachute material (though "hitting the nylon" doesn't have quite the ring of
"hitting the silk"). Rope was also made. The main advantage to using nylon for glider
tow ropes, however, is that it's lighter than ropes made from natural fiber.
George Patterson
Old May 31st 04, 07:47 AM
cvairwerks
and Burma, it became routine? Perhaps it did. Obviously
a C-47 could more easily heft the glider at 100? mph
hacked out of jungle areas. It was pioneered by groups
like Wingate's Chindits. IIRC, it was Wingate's idea.
a way that the tow planes had several hundred yards to
gain speed and were off the ground before drag came on the
I've got some video of how it's done. The lines are laid out
and all slack is taken up prior movement of the tow aircraft
and the glider(s) when the tow aircraft is starting from the
ground. A C-47 can tow two fully loaded CG-4's without a
problem. Both CG's have their own tow lines but the tow
lengths are quite different. Both CG's will end up airborne
almost as soon as the C-47 can get her tail up and off the
tailwheel.
Snatching the gliders off the ground was done with a special
rig installed in the cargo area of the C-47. A cable with a
latching hook mechanism was supported in a position below
the tail when in flight. The cable was run through guides to
a powered winch bolted to the deck. The operator would dial
in the glider weight on the winch and this would set the
drag brakes. The C-47 would make a low pass and snag the tow
bridle that was suspended between a couple of poles. A good
catch would immediately start the glider rolling and at the
same time start paying out cable from the winch. As the
glider became airborne, the load on the tow cable would
decrease and at the same time, the winch would reduce the
cable outfeed. Once the glider was on a stable tow, the
winch operator would reel the glider in or out as necessary
for the best tow position. (Think drag settings on your
fishing reel...same principle, just bigger reels and
weights.)
The First Air Commandos were masters at this, being the
first combat unit to ever use the system for real. A downed
CG-4 was snatched off of a sandbar in a river, using less
than about 100 feet to get it airborne. This was the first
operational snatch in a combat area.
As an aside, the 1st A.C.'s were also the first to use true
helicopters in combat, flying YO-4's from India to Burma
via the Hump in 1944 and using them in rescue operations.
Craig C.
Old May 31st 04, 09:22 PM
Morgans
drag brakes. (Think drag settings on your
weights.)
Craig C.
_That_ is consistent with what I saw. The hook was indeed hung by cables.
The winch with the drag brakes was the missing bit of info.
Thanks.
Version: 6.0.692 / Virus Database: 453 - Release Date: 5/28/2004
Get your Glider Rating - Texas Burt Compton Aviation Marketplace 0 December 1st 04 04:57 PM
WW II glider pilot reunites with aviators in England Otis Willie Military Aviation 0 October 19th 03 11:08 PM
First Glider Flight mike regish Piloting 5 August 4th 03 09:41 PM
WWII glider pilots meet in Sicily Otis Willie Military Aviation 0 July 15th 03 03:11 AM
