TAS measurement
Old June 29th 04, 05:24 PM
Bravo Delta
Default TAS measurement
Can somebody please explain to me the technique to measure your plane's true
airspeed by flying in 3 or 4 different directions for a while and recording
GPS ground speed ? Do you just fly the same amount of time each leg and
average the groundspeed readings ?
Old June 29th 04, 06:22 PM
Newps
"Bravo Delta" wrote in message
true
recording
Go out and fly three headings that are 90 different from each other. It
doesn't matter what they are but it is easier to just use cardinal headings
like N, S, E or W. Let the ground speed stabilize and write down the
ground speed. Then plug it into one of these websites. The website will
also tell you the wind direction and speed. To verify the results use four
cardinal headings and use any three of them. You will see the TAS and wind
come out the same.
www.reacomp.com/true_airspeed/index.html
www.csgnetwork.com/tasgpscalc.html
Old June 30th 04, 04:30 PM
John T Lowry
plane's true
recording
and
Assume you want to know TAS for a given IAS. You'll have to repeat the
following recipe for each IAS you're interested in. ALL speeds must be
in the same units (knots, mph, ft/sec, or whatever).
You will fly N and get GPS ground speed g1, then E to get g2, then S to
get g3.
Now it's time to calculate. There are three preliminary calculations
needed, for P, A, and Q, as follows:
P = (g1^2 + g3^2)/2
A = arctan(g3^2 - g1^2, 2*g2^2 - g1^2 - g3^2) [you have to use the arc
tangent function which gives the angle counterclockwise from the
positive x axis, usually called something like ATAN2(x,y) in
spreadsheets]
Q = (g3^2 - g1^2)/(4*cosA)
Then, at last,
TAS = sqrt((P + sqrt(P^2 - 4*Q^2))/2)
Also, wind speed (assumed constant!!) = absolute value of Q/TAS and wind
angle = 360 deg - A (mod 360).
Hope this helps. If still uncertain, see Performance of Light Aircraft
p. 31.
John T. Lowry, PhD
Flight Physics
Old June 30th 04, 05:07 PM
John Bell
true
recording
One more source:
http://www.cockpitgps.com/other_arti..._compass_and_c
alcul.htm
John Bell
www.cockpitgps.com
Old June 30th 04, 11:55 PM
paul k. sanchez
When doing acceptance flights for purchased aircraft one of the issues is
always how much is the true air speed. Since you are working with an airspeed
indicator that you don't know, an outside air temperature probe that you do not
know temperature rise factor, etc, it is best to use you GPS ground speed.
Technique usually requires a pilot-flying and pilot-non-flying crew. During the
test use the same power (rpm/manifold pressure), fuel flow, and holding
altitude.
Fly a track of 000 for about 30 seconds so that the acceleration/deceleration
forces can equalize, note down the ground speed. Call it groundspeed A
Fly a track of 120 for about 30 seconds so that the acceleration/deceleration
forces can equalize, note down the ground speed. Call it groundspeed B
Fly a track of 240 for about 30 seconds so that the acceleration/deceleration
forces can equalize, note down the ground speed. Call it groundspeed C
A^2 + B^2 + C^2 = sum of (ground speeds^2)
sum of (ground speeds^2) / number of tracks (3) = average of (ground speeds^2)
square root of average of (ground speeds^2) = true air speed at that altitude
with that outside air temperature.
Just a $1.99 calculator from Office Depot can do the trick.
Now of course the question comes in about the validity of the formula.
Lets try 100 knots true air speed, wind 045 at 30 knots (realistic winds at
less than 12k feet). Using our handy dandy Sporty's E6B-F lets input the values
in the HDG/GS function;
WDIR 045
WSPD 30
CRS 000
TAS 100
GS A 76.5
HDG 12.2 degrees
WDIR 045
WSPD 30
CRS 120
TAS 100
GS B 87.9
HDG 103.2 degrees
WDIR 045
WSPD 30
CRS 000
TAS 100
GS C 128.7
HDG 244.5 degrees
Ground speed A^2 (5852.25)
Ground speed B^2 (7726.41)
Ground speed C^2 (16563.69)
sum of A^2, B^2, C^2 = 30142.35
sum of the squares / 3 = 10047.45
square root of average = 100.23696922792508295043396893834 knots
Please note that even with a wind that is 30% of your true air speed, the
percent error using this formula 0.236%. This would cumulate to about
8.5308922053029862156228817788 seconds of leg time error for every 1 hour of
flight.
Close enough I'd say.
paul k. sanchez, cfii-mei
on eagles’ wings
2011 south perimeter road, suite g
fort lauderdale, florida 33309-7135
305-389-1742 wireless
954-776-0527 fax
954-345-4276 home/fax
www.iflyqpa.com/cas
fuel flow measurement khanindra jyoti deka Home Built 0 January 5th 05 04:34 AM
Time Measurement for Inspections O. Sami Saydjari Owning 15 April 7th 04 05:26 AM
units of measurement on altimeters Pat Norton Piloting 30 March 21st 04 06:00 AM
