Two fine points of FAR interpretation
Old July 19th 04, 02:45 AM
Dave Russell
Default Two fine points of FAR interpretation
A friend of mine is curious:
1. If a runway is closed by NOTAM at a non-towered airport, does that
mean that the adjacent *taxiway* can't be used to legally take-off and
land? (I know the insurance company would have an opinion about this,
also, but let's ignore that aspect for the moment.)
2. We all know about the minimum fuel requirement for take-off. If
one were to land with less fuel in the tanks than the required reserve
(and without a good reason for using part of the reserve), can the FAA
violate you for negligence?
Please post in the groups (the email address I'm using here is
primarily a spam-trap) and, no, I'm not in trouble. :-)
-Dave Russell
8KCAB
Old July 19th 04, 03:20 AM
C J Campbell
"Dave Russell" wrote in message
m...
Show me an FAR that requires you to use a runway for taking off and landing.
If you are not allowed to use the reserve, what is it for? The reserve is in
case of unforseen delays. The FAA might do almost anything, of course, but
it is unlikely that they would violate you for negligence if you used part
of your reserve due to unforeseen delays.
Old July 19th 04, 03:58 AM
Capt.Doug
"Dave Russell" wrote in message 1. If a runway is closed by NOTAM at a
land?
Helicopters do it routinely. The antiques land in the grass along-side the
runway routinely. Keep in mind that if you screw up, it will be much harder
to plead your case.
NTSB case law has demonstrated that if you burned some reserves in spite of
doing proper fuel calculations during pre-flight planning, but otherwise
landed safely, you won't be convicted.
D.
Old July 19th 04, 05:12 AM
Jack
Is this a joke?
When does the NTSB get involved post-safe-landing?
Jack
Old July 19th 04, 05:20 AM
Peter Duniho
"Jack" wrote in message
They are the first line of appeal for any FAA enforcement action. The FAA
has been known to issue a violation against a pilot, even if the landing
itself was safe. Most pilots would appeal a negative outcome, so the NTSB
would get involved practically every time.
That's when.
Pete
Old July 19th 04, 12:33 PM
Ron Rosenfeld
On Sun, 18 Jul 2004 23:10:54 -0700, "BTIZ"
when ASH was non towered.. the use of the old grass strip to the east of the
runway was a normal occurrence.. and even more so when the runway was closed
for resurfacing.. and then the heavy twins would use the taxiway.. with lots
of radio calls... but way back then.. there was nothing north of the ASH
tower.. NOTHING but the taxi way to the north end..
That resurfacing must have taken place prior to '76.
But even now, the grass on the NE side of the runway still gets used from
time to time. But they don't keep it up they way they used to.
Old July 19th 04, 04:48 PM
G.R. Patterson III
The regulations require that you have sufficient fuel on takeoff. They do not require
that you have the required reserve when you land. If checked, you might be required
to demonstrate how you calculated the reserve. You might be violated if they think
you did not do a good job of that. I've never heard of such a case in non-commercial
flights, but it's certainly possible.
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
FAA won't fine erratic drunk pilot - Philadelphia Jeff Piloting 0 April 1st 04 01:14 AM
Fine example of Tarver Engineering release for service running with scissors Military Aviation 79 March 3rd 04 01:48 PM
Fine example of Tarver Engineering release for service running with scissors Military Aviation 7 February 28th 04 05:07 PM
Piper Cub: "A Reflection in Time"... fine art print highdesertexplorer Aviation Marketplace 0 January 13th 04 03:47 AM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 08:32 PM
