EAA B-17
Old August 10th 04, 02:04 PM
Ron Natalie
Default EAA B-17
"Marty Shapiro" wrote in message
According to NTSB 830.5 (a) the only accidents with "substantial
damage" are reportable. NTSB 830.2 defines "substantial damage" and
specifically states "Engine failure or damage limited to an engine if only
one engine fails or is damaged, bent fairings or cowling, dented skin,
small punctured holes in the skin or fabric, ground damage to rotor or
propellor blades, and damage to landing gear, wheels, tires, brakes, or
wingtips are not considered "substantial damage" for the purpose of this
part".
Yep...when I had my engine failure and resultant emergency landing...despite
hosing the engine (total loss) and some minor gear and prop damage, there
was no report. Not only that, when the airport manager called the FAA,
they were so busy dealing with a fatal ultralight crash in the next county over
that when they heard there was no injuries and no "substantial" damage they
said forget it. It never showed up even in the FAA accident reports.
Old August 11th 04, 01:35 PM
TaxSrv
I doubt that the NTSB's lack of interest in the B-17 gear-up
landing has anything to do with lack of relevance to other
operators. They aren't interested because it's just not within the
scope of what they are responsible for.
Pete
It definitely is what they're responsible for, but NTSB has a very
small staff. A lot of the work, if not all, is delegated to FAA on GA
accident cases. So if you call FAA and ask if NTSB reportable, and
they say sounds like it's not, it's not reported to NTSB. And if you
don't call for advice, it may not be reported. In many
airframe-destroying accidents, where owner has no hull insurance and
there's no serious injury, the guy doesn't call nobody.
There were two recent "accidents" near here where unsafe hand-propping
caused the plane to just...depart. One flew 60 miles before crashing.
The other tore through a chain-link fence and smashed into a bldg.
Neither was investigated, though both posed a clear hazard to persons
on the ground. In one, I know the owner called FAA, and they said not
reportable, since there wasn't a pilot _inside_ the aircraft.
Fred F.
Old August 11th 04, 06:03 PM
Peter Duniho
"TaxSrv" wrote in message
It definitely is what they're responsible for [...]
Which is, of course, why the regulations specifically exclude such accidents
from being required to be reported to the NTSB?
Yeah, right.
[...] So if you call FAA and ask if NTSB reportable, and
The regulations that address what is required to be reported and what is not
are very clear. Whether someone abides by those regulations is a different
matter, but what the NTSB "cares about" and what they don't is very clearly
described in the relevant regulations.
Without knowing the specifics of the accidents, all I can say is that it's
likely the accidents were required to be reported to the NTSB. Whether they
were or not is irrelevant. If the accidents met the standards for
reporting, then they were supposed to be reported.
As far as the FAA's interest goes, I have a hard time believing that the FAA
position is that, as long as the pilot isn't actually in the aircraft when
the accidents happens, they are not at fault. But that has nothing to do
with reporting requirements to the NTSB in any case.
Pete
Old August 11th 04, 10:44 PM
TaxSrv
what is not are very clear.
"Substantial damage" per NTSB means "damage or failure which adversely
affects the structural strength [or] performance." Are you calling
_that_ clear, or just the exclusion of landing gear and props which
may apply to damage to the B-17?
hand-propping
that
it's likely the accidents were required to be reported to the NTSB.
This rule is clear for a change. An "accident means an occurrence
which takes place between the time any person boards the aircraft with
the intention of flight...." If nobody is in the airplane, nothing
can be an accident.
FAA position is that, as long as the pilot isn't actually in the
aircraft when
the [hand-propping] accidents happens, they are not at fault.
Talking violations now, the FAA doesn't appear to have a clear
definition of "operate" an aircraft, so as to include hand-propping.
They would still have to prove the pilot's intent was to fly, rather
than diagnose a rough mag from the last flight. I suspect most times
they prove it when the pilot blabs and admits it to them.
FAA picks/chooses violation opportunities. In the incident I cited
where the plane had rough sex with a chain-link fence, the pilot
wasn't violated and today flies freight for FedEx. On the one that
flew 60 miles, it was reported in TV media while still in the air,
only gawd knew where. Wouldn't bet more than $1 the pilot evaded FAA
justice. State law could have nailed him too with a misdemeanor; the
guy had no choice but to immediately call 911, but that involved the
local police and State Troopers.
Fred F.
Old August 11th 04, 02:07 PM
R. Wubben
Was it really a gear up landing?
I was under the impression that they had already landed, were taxiing
off the runway when the gear collapsed. I also heard that there was
some sort of jack screw problem that lead to the gear collapsing.
Ryan Wubben
Madison, WI
Old August 12th 04, 04:08 AM
TaxSrv
"Kyle Boatright" wrote:
Also, the EAA has a fair amount of pull, and by going
to the right people in the NTSB and/or FAA, they more
or less headed off an embarassing situation.
Where did you hear that? If there's no substantial airframe (other
than gear) damage, it's not an accident. Even so, how would an NTSB
report embarrass EAA? If true, a guy pulled the wrong switch. NTSB
would say he pulled the wrong switch in a short report media wouldn't
care about. And pulling the wrong switch is in no way reckless
operation, due alone to the fact it did not endanger persons/property,
so FAA should not be involved. Nobody has pull with NTSB, not even
FAA; NTSB made even Boeing redesign the B-737 rudder control system
they insisted worked properly.
F--
Old August 11th 04, 04:12 PM
Joe Maj
EAA source told me it was pilot error, the jackscrew positions (which
can't be reversed by an impact) are an infallible marker and were
something like 70% extended.
"Peter Duniho" wrote in message ...
Why not? Are you trying to say that the B-17 is so completely different
from other aircraft that a gear-up landing in a B-17 has absolutely NO
parallels with a gear-up landing in any other aircraft, no similarities at
all?
In that particular case, if I recall, there was a mechanical failure. But
until someone's actually investigated the cause, there would be no way to
know that.
Pete
Old August 11th 04, 08:45 PM
John Stevens
But, this was not a gear up landing. It was a gear collapse while
taxiing. I suppose there might be some crossover to GA if it was pilot
error and B-17's had no "weight-on" interlock.
"G.R. Patterson III" wrote in message
[...]It's hardly likely that anyone is going to learn anything from
a gear-up on a B-17 that will help prevent another incident.
all?
know that.
Personally, I think that gear-up landings most often happen for very similar
reasons, ones that don't have anything to do with the specific aircraft type
at all. I doubt that the NTSB's lack of interest in the B-17 gear-up
landing has anything to do with lack of relevance to other operators. They
aren't interested because it's just not within the scope of what they are
responsible for.
Pete
