Handheld GPS Recommendations?
Old August 16th 04, 02:49 AM
Shirley
Default Handheld GPS Recommendations?
Shopping for a handheld GPS. Anyone have recommendations, advice, or cautions?
What features are "must haves"? Which did you think you'd use but don't? Thanks
in advance!
Old August 16th 04, 03:16 AM
Apa
I would recommend www.cockpitgps.com.
It's a must have - a great work! You should get an answer to all of your
questions there.
Apa
"Shirley" wrote in message
cautions?
Thanks
in advance!
Old August 16th 04, 06:21 AM
Ardna
I have an Lowrance Airmap 500 and love it. Ships with yoke mount, Mapcreate
6 software, a MMC/SD card reader, a 32mb card for the Airmap and an external
antenna all included.
For approx $400, well worth the money. Has an excellent HSI screen.
Ardna
"Apa" wrote in message
. cable.rogers.com...
questions there.
Apa
cautions?
Thanks
in advance!
Old August 16th 04, 09:27 AM
Thomas Borchert
Shirley,
Well, a few questions to narrow the field:
1. What's your budget?
2. Do you want color?
3. Do you want land navigation, too?
4. Do you own a PocketPC PDA?
Many people tend to look only at the Garmin line of products. However,
Lowrance has a very attractive range, too, and both Jay Honeck and
Aviation Consumer like the AvMap EKP.
Depending on what you need, the choice is more or less between
1. Small, cellphone form factor, light, ultraportable - the Lowrance
Airmap 500 and the new line of Garmins fill that bill
2. Big display greyscale unit. The Lowrance Airmap 1000 and the Garmin
196 do that - at different prices.
3. Big screen color display. Airmap 2000, Garmin 296 and newer, AvMap.
If you answer 4. in the positive, you might want to use your PocketPC
with some software - might provide more options, but adds the "hassle"
factor of PCs.
if you need car nav, too, the Airmap 2000 seems to be the most
cost-effective solution.
Thomas Borchert (EDDH)
Old August 16th 04, 01:34 PM
Shirley
Thomas Borchert borchert_thomas asked:
Open to all, just don't want to buy the most expensive if it has a lot of
features I'll never use, and don't want to buy one for half the price and wish
I'd gotten the one with everything!
That's one of the things I wanted input on. How important is it? Does it make
it easier or more difficult to see? I've heard that the color one is harder to
see in sunlight. Is that true?
Not my first criteria, but wouldn't mind having it.
No.
of products.
That's all I've seen/read about so far.
I was about to take the plunge and get the Garmin 296 when someone said that at
Oshkosh, Garmin just introduced a two new ones for half the price. Do they have
half the features, too? How do they compare to the 196 and 296?
Is the G296 the ultimate, "probably won't ever need anything else" choice?
Old August 16th 04, 02:17 PM
Thomas Borchert
Shirley,
don't forget, you're getting my take on this. YMMV.
I don't think so. If the planes you fly usually have a panel mount color unit and
the handheld will be a pure back-up, IMHO you don't need color. In all other
cases, it makes the map much better to read.
The upscale color units come with that as an option. What you want, though, is
true turn-by-turn instructions, ideally with voice annunciation. Garmin's 296 has
an add-on kit (for a fee) for that with no voice, AFAIK. Lowrance promises that
feature AFAIK including voice for a future free software upgrade to the 2000c.
Not sure about AvMap.
They do have fewer features, among them a much smaller display and fewer display
options. Look at the Garmin site for specifics.
Probably not. It all depends on your needs and preferences. As I said, I think
the Lowrance units are VERY interesting, since they tend to offer the same or
more at a lower price - e.g., look for the accessories that are included. Also,
if you want a truly luxurious display, the AvMap looks awesome. Don't know about
their support, but my simple e-mail inquiry regarding international mapping went
unanswered. They are definitely the smallest company of the three - which can be
both good and bad.
Look at the price for database updates, too, although you'll probably only need
one per year or so.
Old August 16th 04, 06:09 PM
Michael
I would add a few:
Will you fly IFR? Will you have an IFR GPS when you do? With moving
map?
Frankly, I have been very underwhelmed with the Lowrance products.
They're well-built and they work fine, but the user interface feels
like it was designed by an engineer with the help of a low time pilot.
I find it counter-intuitive; an airline pilot friend of mine bought
one of the high end models (a 1000, I think, which, it terms of
price/performance blows away the Garmin) and found it unusable - he
bought a Garmin and is selling the Lowrance on Ebay.
My suggestion is try before you buy - and by try I mean make a flight
with one. You may discover that you like the Lowrance user interface
just fine since you're not already used to something different; then
again you may not.
Another friend of mine has a PDA-based system; I find it essentially
unusable since it requires the use of the stylus. On the other hand,
I don't normally use a PDA at all. If you use your PDA all the time,
you may find it to be the most convenient system.
A lot of this will depend on how you use the GPS - for VFR-only use,
you can get by with something that will just **** you off when you get
a reroute IFR. All I'm saying is, don't overlook the user interface.
At this point, most GPS units have more functionality than the average
pilot really needs. What really differentiates them is the user
interface.
Michael
Old August 17th 04, 12:35 AM
Hankal
a reroute IFR
One reason I have the AvMap. Ease of operation and big screen
Hank 172 driver
Old August 16th 04, 10:33 AM
Cub Driver
I use a Garmin III Plus, civilian model. See
www.pipercubforum.com/garmin.htm
Sometimes I hanker for a 196, sometimes for a 296. Meanwhile the plain
vanilla version gets me where I'm going and is marvelously thrifty
with batteries.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
Expedition sailboat charters www.expeditionsail.com
Old August 17th 04, 11:43 AM
Darrel Toepfer
Thanks for the link. I have had a 3+ for many years and a 3 Pilot (came
with a recent 172 purchase) and you've provided a method to get more
aviation use out of it (the 3+). The primary for our plane(s) has been
the Lowrance Airmap 1000, we're on our second one (2000c wasn't
available yet). I do however have a Magellan 315 that always has the
most current airport database information, its available for free from he
http://home.stny.rr.com/bkw/315
The 315's are by far the cheapest thing I've found out there. I picked
mine up for $125 and that included the power adapter, serial interface
and Datasend software (required for POI transfers). Reception has been
excellent, even back inside the cabin mounted on the yoke. I have
however seen more satellites at the same time, on the 3+. The 315 will
hold around 18,000 POI's (Points of Interest), which allows me to do all
of the 48 states, VFR/ILS and NDB approaches and Seaplane bases. You
have to be careful to not overload it, Datasend will state that you are
under the limit, but actually you do exceed it and it will fault during
the transfer. A drawback of this unit over the others, is that it
doesn't display roads. On the road I use a notebook with mapping
software that gives visual/audible turn by turn instructions though...
with batteries.
I use rechargeables in the 3+ and assumed that they were replenished
with external power. A recent trip to/from Ohio showed that they aren't...
One downfall of the 315 is that it has an internal backup battery that
cannot be user replaced. It is normally recharged by the 2 AA batteries
and if it geaux's south, it'll eat those overnight. Otherwise a good 5
hours or more is likely with battery only operation from Alkaline or
rechareables. Much more I assume if the internal battery is still good.
Downside of pulling the batteries after every use is the need to
reinitialize each time you fire it up...
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Terrain-Aware Handheld vs. IFR GPS? C Kingsbury Instrument Flight Rules 7 November 14th 04 05:33 AM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
TSA's General Aviation Airport Security Recommendations Might Become Requirements Larry Dighera Piloting 1 February 25th 04 05:11 PM
