Unnecessary verbiage or sensible redundancy?
Old August 31st 04, 05:07 PM
Tony Cox
Default Unnecessary verbiage or sensible redundancy?
I've had a smoldering dispute with a CFI friend of mine for
years about whether to announce (say) "zero-two" or just
"two" when operating at an uncontrolled field with runways
2-20. My friend is of the opinion that the extra "zero" is
superfluous, whereas I've always instinctively said "zero-two"
without really understanding why I do it. It has always "just
seemed right", with a blank in the orderly transmission of
information that cried out to be filled.
This weekend I felt vindicated. As I started to taxi out at
0L7 (two runways, 2-20R and 2-20L), I was not particularly
surprised to hear a Cherokee doing touch-and-gos on runway 2 (the
wind was 5 out of the north). Listening to several calls as I
prepared to depart, I finally caught a "two-zero" -- the fellow,
out of exuberance or lack of currency was letting his finger
slip off the transmit button to give an entirely erroneous and
completely believable false impression of what he was up to.
Turns out he was practicing downwind landings. Add to that
that the airport is right traffic for 20 and left for 02, the potential
for disaster is evident.
So what do instructors teach these days? Do you add the
extra zero or not?
Dr. Tony Cox
Citrus Controls Inc.
e-mail:
http://CitrusControls.com/
Old August 31st 04, 05:14 PM
zatatime
extra zero or not?
Yep, for exactly the same reason you found out that day. With only
one number you don't know if you've missed part of the transmission.
z
Old August 31st 04, 05:31 PM
XMnushaL8y
mine for years about whether to announce (say)
"zero-two" or just "two" when operating at an
uncontrolled field with runways 2-20.
[snip]
add the extra zero or not?
No, I agree with your CFI-friend. A local uncontrolled airport has runways
3/21. I've never heard anyone announce "zero three" when referring to Runway 3,
nor was I taught to do so by my CFI. Recorded ATIS announcements don't add
zeros either -- they just say, "landing and departing Runways 4 left and
right."
Old August 31st 04, 06:05 PM
Neil Gould
Recently, Tony Cox posted:
potential for disaster is evident.
extra zero or not?
At some point, common sense has to play a part in what you say or omit. I
believe that it is important to eliminate ambiguity, so in the case of
runways that have the potential for confusion, as is the case with "two"
vs. "two zero", I would do as you did, and say "zero two". Note that in
either case, the potential for losing part of the transmission exists, and
if so, the same ambiguity is created as before. But, at least you've done
what you can to reduce the ambiguity.
Neil
Old August 31st 04, 06:26 PM
Gary Drescher
"Tony Cox" wrote in message
ink.net...
2-20...
The AIM's radio phraseology section doesn't seem to address this question.
However, an example in AIM 4-3-11c2 refers to "runway six right", which is
the phrasing I've always heard from ATC or ATIS at controlled fields. So I'd
vote for "runway two", more for standardization than for concision.
If you follow the standard practice of beginning and ending a unicom or
multicom transmission with the name of the airfield, then your listeners
will not be left wondering if there was an extra digit after the "runway
two" at the end of your transmission, unless they fail to hear the
concluding mention of the airfield.
--Gary
Old August 31st 04, 07:00 PM
Bob Gardner
Two part answer. First, runways with single-digit designators (1,2,3, etc)
do not have a preceding zero painted on them. Second, FAA-P-8740-47 "Radio
Communications Procedures and Techniques," which hardly anyone has or has
read, says that if there is more than one digit, each digit should be
spoken, as in "one three" rather than "thirteen." If there is only one
digit, there is no reason to enunciate two digits.
However, don't be surprised to hear a controller say "Climb and maintain one
one thousand, eleven thousand" because there have been some
readback/hearback problems with pure digits.
Bob Gardner
ink.net...
extra zero or not?
Dr. Tony Cox
e-mail:
Old August 31st 04, 07:36 PM
Ben Jackson
On Saturday I heard an airliner call in at "one one thousand, ten thousand".
He quickly corrected himself. No amount of redundancy helps if your brain
isn't in gear.
Ben Jackson
http://www.ben.com/
Old August 31st 04, 08:29 PM
CB
"Bob Gardner" wrote in message
Flying in the UK it is the reverse. The runway will have 02 painted on the
runway and you will be expected to say zero two. Saying "runway 2" would be
confusing and leading people to believe you meant something from 20 to 29.
Funny how it goes.
Old August 31st 04, 08:42 PM
Tony Cox
"CB" wrote in message
be
So *that's* where I got it from. Being English myself, it must
be some sort of racial memory...
Generators, redundancy, and old stories Michael Owning 2 March 3rd 04 06:25 PM
