Best Glide Speed
Old September 4th 04, 01:32 AM
john smith
Default Best Glide Speed
Does Best Glide Speed reduce with weight the same as other airspeeds?
Old September 4th 04, 02:02 AM
kontiki
Best glide speed is a determined by the interection of the parasitic drag
curve and the induced drag curve. Parasitic drag is not going to be affected
by weight but induced drag is somewhat affected by weight as well as the
location of the CG. So, yes, it *could* reduce or increase slightly depending
on the CG.
Old September 4th 04, 03:02 AM
Raymond Swartz
Yes, weight does have an impact on best glide speed. That is why glider
pilots in competition (or whenever they need a high speed, like long
flights limited by daylight) carry water ballast in the wing tanks. It
doesn't affect the glide angle too much, but it does have an impact at
which airspeed that best glide angle occurs.
Go check out a glider contest sometime.
I recall crewing for one once, and fondly remember the view, as the
afternoon wore on, of the gliders returning to the airport from the
direction of the setting sun. We could first see them at about 15 miles
distance as bright points where the sun was reflecting off the white gel
coat. As they got closer we could make out the glider shape. Then about 5
miles out the sun started refracting through the "contrails" of water
ballast being dumped as they approached the finish line.
That particular contest had 6 gliders crossing the finish line at 100
knots within 2 minutes of each other.
Ray Swartz
Old September 4th 04, 03:22 AM
G.R. Patterson III
Yes.
George Patterson
If you want to know God's opinion of money, just look at the people
he gives it to.
Old September 4th 04, 05:03 AM
Peter Duniho
"Raymond Swartz" wrote in message
It doesn't affect the glide angle at all, oddly enough. The lift/drag ratio
remains the same, which results in the same glide ratio. You just have more
lift and more drag.
Old September 4th 04, 10:04 AM
Julian Scarfe
"Peter Duniho" wrote in message
ratio
more
lift and more drag.
It does affect the glide angle a little.
The model that infers that glide angle is independent of weight assumes a
parasitic drag coefficient that is independent of speed. In reality it's
not. Skin friction drag coefficient reduces as speed to the power 0.2 for
turbulent boundary layers and speed to the 0.5 for laminar boundary layers.
Thus the faster (heavier) glider actually has a higher L/D.
Thus at 20% higher weight, 10% higher glide speed, the skin friction
(approximately a quarter to a half of the drag) is between 2 and 5% lower.
So the glide ratio will be something like 0.5 to 2.5% better.
Is it significant? Well, maybe. Bear in mind that we're always taught to
nail that best glide speed. Getting the airspeed wrong by 5% costs you
just 0.5% of your glide angle, and getting it wrong by 10% costs you just 2%
of your glide angle. So the numbers are the same sorts of magnitude.
Julian Scarfe
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 08:35 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
New Film: The Need For Speed - Going to war on drugs Phil Carpenter Military Aviation 0 July 23rd 03 07:43 AM
