Thanks for your response.
I appreciate that you took the time to respond. 3-monitor cards can be had more easily than you think. Who said anything about "new". There are many second-hand locations, including Ebay, where you can get a good deal on a pretty decent 3-monitor card. In fact, although it's not below $100, I recently ordered a surplus Matrox 3-something card that is fairly new, 3 monitor output plus an S-Video output for $119. Not bad, eh? Anyways - thanks for your response. I'll have to look more into MS 2004 - it says multi-monitor support, but it's not clear if it supports 3 and what can be displayed. Sometimes it's non-3D kneeboard or other stuff. I want 2 side scenery displays! Regards, Gary |
Gary G wrote:
Thanks for your response. I appreciate that you took the time to respond. 3-monitor cards can be had more easily than you think. Who said anything about "new". There are many second-hand locations, including Ebay, where you can get a good deal on a pretty decent 3-monitor card. In fact, although it's not below $100, I recently ordered a surplus Matrox 3-something card that is fairly new, 3 monitor output plus an S-Video output for $119. Not bad, eh? Anyways - thanks for your response. I'll have to look more into MS 2004 - it says multi-monitor support, but it's not clear if it supports 3 and what can be displayed. Sometimes it's non-3D kneeboard or other stuff. I want 2 side scenery displays! Regards, Gary There is new technology by NVIDIA that allows you to hook multiple GPUs together so instead of running 3 monitors off three monitors, you can run 3 monitors off 3 (or more) video cards. This way there will be no power loss from the ultra high resolution of three displays. It would be expensive, but awesome as heck. link: http://www.nvidia.com/page/sli.html |
I did this with (2 screens on) FS2002 a couple of years ago. Off memory it
was a little triky to resize the views and place them where I wanted them, but the biggest issue (at the time) was the hit on performance - 25 fps on one screen -v- around 5 fps with 2 monitors going - although obviously things have improved a lot since then. Food for thought - many video cards these days have 2 outputs - the usual 15 pin mini-din and another (digital?) output - which you can convert to a 2nd 15 pin mini-din with a cheap adaptor (we do this all the time). For a 3rd monitor consider using any old PCI based card and use it just for the instruments? |
Good idea - thanks for the info!
35th's Life Support Section named best in the Air Force | Otis Willie | Military Aviation | 0 | July 16th 04 11:08 PM |
24/7 computer tech support | [email protected] | Home Built | 0 | May 5th 04 03:32 AM |
LONG DEPLOYMENTS, BENEFIT CUTS ERODE SUPPORT FOR PRESIDENT | Ewe n0 who | Military Aviation | 0 | March 17th 04 07:57 PM |
USAFE commander: 86th Airlift Wing will divide for combat, support operations | Otis Willie | Military Aviation | 0 | November 27th 03 11:31 PM |
