Story: Propeller found miles from crash scene
Old October 14th 04, 09:52 PM
H.P.
Default Story: Propeller found miles from crash scene
http://www.newsday.com/news/local/wi...-regional-wire
Old October 15th 04, 03:46 AM
StellaStar
http://www.newsday.com/news/local/wi...1014oct14,0,74
34473.story?coll=ny-ap-regional-wire
MADISON, Conn. -- The propeller from the plane that crashed into a house on
Lovers Lane Monday night has been found a few miles away in Killingworth.
Police Chief Paul Jakubson said police received a call Wednesday from a
resident of Maple Hill Road in Killingworth, which is 2 to 3 miles from the
crash site.
So...did it pop off and zing all that way ahead of the crash scene...or drop
off before they dropped out of the air?
Old October 15th 04, 05:45 AM
Bob Gardner
A founding member of the Compuserve Aviation Special Interest Group, who is
regrettably no longer with us, lost the prop on his GlasAir and watched as
it flew off into the distance....there's a heck of a lot of pressure on the
back side of the propeller disk. He survived the landing.
Bob Gardner
"StellaStar" wrote in message
on
crash site.
drop
Old October 15th 04, 08:03 AM
Morgans
"Bob Gardner" wrote in message
is
Bob Gardner
Yes, but not 2 to 3 miles.
I have been passed by a hubcap, but passed it again pretty soon.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.776 / Virus Database: 523 - Release Date: 10/12/2004
Old October 15th 04, 11:55 AM
Bushy
I have been passed by my right rear tyre in a kombi one night many moons
ago.
Before I lurched to a stop, I tried to decide if it was real, or a result of
all those nasty things I used to do to my body!
Peter
Old October 15th 04, 12:40 PM
H.P.
He was returning the plane to the Danbury Flight School at DXR from
Nantucket (ACK). Drawing a straight line on a map from Nantucket to Danbury,
Madison and Killingworth are on the same line and Killingworth is 2-3 miles
closer to Danbury.
Griswold Airport (MPE) is in the same town where he went down
(Madison).Wonder how (specifically) the dislodged prop affected the
aerodynamics of the Warrior and his chances for a controllable glide.
(Student here, please be be kind!)
drop
on
crash site.
(added
The 1978 Piper Warrior smashed through tree branches before crashing into
the roof of a house.
Hanlon and Johnson, who were co-workers at the U.S. Post Office in
Brookfield, were flying from Nantucket to Danbury when Hanlon
radioed in a "mayday" shortly before 6 p.m. to report that the
engine had stopped working.
Old October 15th 04, 12:49 PM
jls
"H.P." wrote in message
om...
Danbury,
miles
closer to Danbury.
An account of an aerobatic Pitts losing a prop said that the pilot used full
forward stick and the aircraft still flared with nose up just before the
pilot got it on terra firma. If he hadn't gotten it down it would have
gone into a flat spin. I remember reading about it in the nineties. Of
course, a part of the crankshaft departed with the propeller.
To me, losing a prop on a single-engine tractor aircraft means instant loss
of power, an aft CG outside of the envelope, and a life-threatening
encounter with the earth's gravitational pull.
Old October 15th 04, 03:10 PM
Rick Durden
"Morgans",
Actually, two or three miles is not at all unusual if a prop is flung
at altitude. The event is not nearly as common as it used to be (prop
design is better, so it usually is an indication of serious
maintenance neglect). If you go back into the historical record props
came off of hubs with a distressing regularity prior to WWII, but
continued from time to time since then. Depending on the altitude of
the airplane when the prop departs and the direction the pilot turns
in gliding to a landing (assuming no major damage to the airframe
caused by the departing prop, and the airplane is controllable), the
distance between propeller and airplane can be several miles.
There is a good discussion of the topic in the era between the World
Wars in _The Eighth Sea_ by the late British test pilot, Frank T.
Courtney. Very good and interesting book.
Friend of mine flung the prop off of a Grumman Ag-Cat he was flying.
As he pulled up off of a spray pass, having just shut off the
chemical, the engine rpm went up radically and the airplane
decelerated sharply. He was at about 50 feet agl, stuffed the nose
down, but still stalled a few feet above the ground, hit hard and
flipped. He was unhurt. After he got out, wondering what in the
world had happened (he didn't see the prop go), he walked around the
airplane a few times before he realized the prop was missing. It was
never found.
All the best,
Rick
"Morgans" wrote in message ...
is
Bob Gardner
Old October 15th 04, 03:13 PM
Dale
A prop for most light aircraft weights about 80 pounds for a constant
speed unit, much less for a fixed pitch prop. I don't anticipate that
on most GA aircraft the CG will go so far aft that you'll have control
problems,unless already loaded with the CG well aft.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old October 15th 04, 03:30 PM
Bob Chilcoat
A quick back-of-the-envelope (unintentional pun) calculation, assuming a
Cherokee/Warrior prop weighs around 25 lb and is 6" back from the datum
shows a shift in CG of about 1.5" aft. Hardly life threatening. OTOH,
without a prop, the glide ability would really be improved, and it might be
very difficult to judge an approach under those circumstances. He might
have just landed really long compared with where he was hoping to set it
down.
My dad used to tell the story of a Corsair prop that departed the a/c during
a runup somewhere in the Pacific. It flew all the way across the airfield
at low level and was found several hundred feet into the jungle at the end
of an impressive swath cut through the bougainvillea. Depending on the
altitude and RPM at the time of loss, I can easily imagine a lost prop
traveling a mile or two before it hit the ground.
Bob (Chief Pilot, White Knuckle Airways)
I don't have to like Bush and Cheney (Or Kerry, for that matter) to love
America
" jls" wrote in message
loss
George W. Bush Abortion Scandal that should have been Psalm 110 Military Aviation 0 August 12th 04 09:40 AM
F4U inverted gull wings Bob M. Military Aviation 52 July 16th 04 02:11 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
PFC Lynch gets a Bronze Star? Brian Military Aviation 77 August 2nd 03 11:15 AM
