Some flight plan software requires one to enter a power chart for the aircraft. This
is used to calculate time enroute at different altitudes and temperatures. The chart has TAS for various combinations of altitude and power. Given the single airspeed/altitude/power setting provided by the aircraft manufacturer, can one of these charts be created mathmatically? If so, how? George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
![]() "G.R. Patterson III" wrote: Some flight plan software requires one to enter a power chart for the aircraft. This is used to calculate time enroute at different altitudes and temperatures. The chart has TAS for various combinations of altitude and power. Given the single airspeed/altitude/power setting provided by the aircraft manufacturer, can one of these charts be created mathmatically? This sounds unclear to me, so it probably is to you. I need to enter power percentage, GPH, and TAS figures for several rpm settings at, say 3,000' and the same info for 10,000'. I can get the percentage and GPH figures from the Lycoming engine data charts. Maule, however, just says that TAS is 103 knots at 8,500' at 75% power. How can I derive the TAS values I need? George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
![]() "G.R. Patterson III" wrote in message ... "G.R. Patterson III" wrote: Some flight plan software requires one to enter a power chart for the aircraft. This is used to calculate time enroute at different altitudes and temperatures. The chart has TAS for various combinations of altitude and power. Given the single airspeed/altitude/power setting provided by the aircraft manufacturer, can one of these charts be created mathmatically? This sounds unclear to me, so it probably is to you. I need to enter power percentage, GPH, and TAS figures for several rpm settings at, say 3,000' and the same info for 10,000'. I can get the percentage and GPH figures from the Lycoming engine data charts. Maule, however, just says that TAS is 103 knots at 8,500' at 75% power. How can I derive the TAS values I need? George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. At a minimum, you'll need your airplane's drag polar, which requires numbers CD0 (parasite drag coefficient) and e (airplane efficiency factor), which in turn requires only a fairly simple glide test. It's all outlined in Performance of Light Aircraft. Other things you might or might not need are in there too. John Lowry Flight Physics |
eScrew zen story | [email protected] | Owning | 0 | December 20th 04 07:19 AM |
Funny story about naval | [email protected] | Naval Aviation | 0 | December 20th 04 03:37 AM |
Power management on a O-300 | Victor | Piloting | 0 | July 9th 04 01:09 AM |
Piper Pathfinder Article | john smith | Piloting | 24 | March 14th 04 01:04 AM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
