How Long Can An Airplane Sit?
Old October 24th 04, 05:00 AM
Bill Denton
Default How Long Can An Airplane Sit?
A pilot owns an airplane.
He isn't able to fly the plane very often, but when he does it's usually two
hours out for a $100 hamburger, then two hours back.
The airplane is always hangered; all inspections and maintenance are done by
the book.
How long could the airplane sit between flights before it begins to
deteriorate?
Old October 24th 04, 05:34 AM
Steven Barnes
"Bill Denton" wrote in message
two
by
the book.
deteriorate?
Approx 2 days. At least that what *my* plane needs. ;-)
Of course my wife thinks it can sit for weeks...
Old October 24th 04, 06:26 AM
tony roberts
One week
If you can 't fly it every week, pickle the engine.
Sorry - but that's how it really is.
Tony
the book.
deteriorate?
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H
Old October 24th 04, 07:18 AM
Peter Duniho
"tony roberts" wrote in message
news:nospam-5887C9.22294723102004@shawnews...
One week
That's just silly.
Yes, a week is short enough for corrosion to occur. A few hours is, for
that matter (and that's the literal answer to the original question), and of
course every day you go without flying incurs additional damage.
But honestly, you obviously don't own an airplane. No owner would seriously
consider pickling the engine for a mere week of downtime. Most owners
wouldn't go to that much trouble for less than a couple of months or more of
downtime. It's just not practical.
Anyway, to the original poster: as I said, as you asked "before it *begins*
to deteriorate" (emphasis mine), the answer is a few hours after shutdown.
Corrosion is a constant process, and the longer you go, the worse it is.
It would be best for an airplane to be flown at least once a day, if not
multiple times a day. A week's not bad, nor are two. Beyond that, you are
likely going to see noticeable long-term effects on maintenance and engine
life.
You may be able to minimize the effects by using certain oils (Exxon claims
to have an oil that nearly eliminates corrosion even after long periods of
time), or that might just be marketing hype. I'm not aware of any unbiased
tests that would indicate one way or the other.
Pete
Old October 24th 04, 03:45 PM
Stealth Pilot
On Sat, 23 Oct 2004 23:18:55 -0700, "Peter Duniho"
lets blow away the mystery here. yes corrosion can start in a few
hours ....but why????
my aircraft with an O-200 in it has sat for a year at a time unused on
two occasions. on the first occasion the accessory drive at the back
of the engine disintegrated requiring some major work. on the second
occasion it has now flown 2 years subsequently incident free. why??
bull**** (and I mean that in the nicest way :-) )
life.
ok why??? what is the actual process going on here that makes the
running better?
what effects???
of course there are. you just havent read of them. :-) :-)
ok let me answer the questions I posed in tickling peter in the ribs.
moisture in the engine is primarily the bad guy here.
it condenses in the oil as the engine cools after use and will
actually emulsify (well that it what it looks like to me) through the
oil on to the steel surfaces and set off corrosion.
it is worse in winter than in summer and this is probably the one
thing that a hangar offers no protection against.
in my aircraft the first time it sat for a period unloved (the last
owner was sick and grounded for the year) there must have been
moisture/water in the oil. the bearing surfaces in the gear train
within the accessory case all corroded on to the gears. of course as
well as gluing the bits together the corrosion roughens the bearing
surfaces.
crud in the gallery obstructing the oil flow and roughened bearing
faces saw the gear train sieze and part company about half an hour
into the first subsequent flight.
the second time I took precautions to minimise water in the oil and
had no identifiable damage.
there are two methods of making sure the oil and the inside of your
engine is moisture free.
always fly the engine for a minimum of an hour after it has warmed up.
this will assist considerably in boiling off the moisture in the oil
(so thats what the breather tube is for on the engine :-) )
the other technique if you can only make short flghts is to change the
oil regularly. fresh oil is moisture free.
a third technique is to drop the oil into a container. boil it dry on
a stove then put it back into the engine. oil fires are horrific
though and nowhere as much fun as just flying it dry.
if you know that the aircraft is to sit for a long period put fresh
oil into it and run it for a minute or two to get fresh oil in all the
galleries and bearing surfaces then shut it down.
worked for me.
Stealth (there you go a mystery evaporated) Pilot
australia.
btw this matter has been subject of safety advisories in this country.
Old October 24th 04, 06:11 PM
Peter Duniho
"Stealth Pilot" wrote in message
Because moisture is always present. No mystery...not sure why you say there
is.
Doesn't matter how nice you mean it...you're still wrong.
running better?
Mostly it's the recurrent coating of corrosion-susceptible surfaces with
oil, protecting them from moisture. Again, no great mystery.
[...] I'm not aware of any unbiased
I'm all ears. Show me an unbiased report that compares efficacy of the
corrosion-preventative oils. I would love to be proved wrong, as such a
report would be very useful to aircraft owners.
It is also present in the air, and the engine not being a sealed
environment, humidity will get into the engine as it sits, regardless of how
much moisture got into the oil as a result of operating the engine.
How did you attempt to identify the damage? Did you disassemble the engine
and inspect it for corrosion? Where was the airplane stored? Was it in a
desert (extremely low humidity) or in a coastal environment (high humidity)?
Regardless of the answers to the above questions, two years in service is
not enough time for you to notice the effects of corrosion. If you think
that corrosion did not occur in your engine during the second year it sat
unattended and unoperated, you are fooling yourself. The degree of
corrosion is highly variable, but to say that corrosion did not occur is
just stupid.
Pete
Old October 24th 04, 11:16 AM
Cub Driver
One week
The same is true of the pilot, of course.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
Warbird's Forum
www.warbirdforum.com
Piper Cub Forum www.pipercubforum.com
the blog www.danford.net
Old October 25th 04, 01:24 AM
G.R. Patterson III
Cub Driver wrote:
One week
If you can't fly every week, pickle the pilot? I'll drink to that!
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old October 24th 04, 07:19 AM
Brien K. Meehan
Mine complains if I don't fly it about once a week.
Old October 24th 04, 09:01 AM
Ben Jackson
In article .com,
You have a voice annunciator for corrosion?
Ben Jackson
http://www.ben.com/
Interesting Resume (V Long) Bob Chilcoat Piloting 24 September 13th 04 06:44 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
