A wacky idea
Old November 11th 04, 10:09 AM
Ramapriya
Default A wacky idea
Is it not possible to have buttons inside the cockpit that perform a
set of checklist actions that pilots normally do at various phases of
flight and save pilots that bother? I'd have thought it nice for a
button to activate an electronic pre-flight check and report an AOK
Ramapriya
Old November 11th 04, 03:11 PM
Jose
Would you trust it?
Jose
Freedom. It seemed like a good idea at the time.
Old November 11th 04, 03:19 PM
BTIZ
we do... it's called a "voice actuated co-pilot"
B
"Ramapriya" wrote in message
om...
Ramapriya
Old November 11th 04, 03:35 PM
Gary G
You're right - it is a wacky idea!
I actually prefer hiring an intern to insure that I'll live through the flight.
The "button" would certainly do a better job, though.
Wait - I think I found a plane that has this feature!
Here's a picture of the cockpit and a demo:
http://www.gilbert-land.com/AOK.html
I think I'm going to look into this and potentially purchase this feature!
Old November 11th 04, 04:40 PM
C Kingsbury
om...
Well, you're still going to need a checklist to check that one button.
Now, let's look seriously at this and see why it's a false idol. One generic
pre-landing checklist is called GUMPS (it's an acronym- pilots love acronyms
for checklists). It can be used on almost every propeller plane from a
little 2-seat trainer to a multi-engine turboprop with small modifications.
It stands for the following items:
Gas- set throttle for landing
Undercarriage- lower landing gear
Mixture- set fuel mixture to full rich
Prop- set landing RPM
Switches- radios on proper frequency
Now, to have a "magic switch" that performs all of these tasks would
actually be quite complicated. The landing gear is just an on-off electrical
switch so that's pretty simple. But the throttle, mixture, and prop are all
mechanical controls, and would require some kind of servomotor to drive
them, just like an autopilot. Now guess what? You're going to need a
checklist to make sure all of those systems work before you depend on them.
So you've made the plane heavier and more complicated but not really saved
the pilot any trouble.
One thing you need to understand is that while the aviation business and
pilots in general love to talk about new technology, we are in fact often
quite conservative about using it. The reason is that new technology is by
definition unproven technology, and the consequences of failure in flight
are often fatal. Compare this to, say, boating. If the engine in your boat
fails, you wait there, drink some beer, and wait for the towboat to show up.
If all your electronics die and you're in terrible fog, you motor along very
slowly back to port so if you hit something, you probably don't sink. And
even if you sink, you probably don't die right away, and many people are
pulled out of the water after all kinds of awful things happened to their
boats. Suffice it to say that the tolerance for errors in airplanes is quite
a bit lower.
-cwk.
PS- May I offer a gentle suggestion that the forum "rec.aviation.student"
would be the best place for many of your questions?
Old November 11th 04, 05:04 PM
Allen
"C Kingsbury" wrote in message
nk.net...
om...
generic
acronyms
modifications.
Mine are a little different -
Gas - fuel selector on the proper tank
Undercarriage - down and locked
Mixture - set fuel mixture to desired position
Prop - set for desired RPM
Seatbelts - confirm everyone has their seatbelt fastened
Allen
Old November 11th 04, 09:16 PM
Stefan
Actually, the Thielert diesel does exactly this, at least concerning the
power plant and the prop governor. You press a butten, and the system
does a go/no go decision for you. It does so based on a set of engine
parameters which aren't directly accessible to the pilot.
Stefan
Old November 12th 04, 07:21 PM
Dave
I always walk around and check the tires, oil, battery connections,
and etc before a long trip. And that's just my automobile, which I
ensure always stays at 0.0 AGL with no roll, pitch nor yaw.
~D
Old November 14th 04, 06:10 AM
Peter R.
Does anyone ever take their seatbelt off in a small aircraft? My
preflight brief instructs the passengers to always leave their belt on.
Peter
Old November 14th 04, 06:24 AM
Jose
Sometimes people do, for reasons that don't really matter. The time to find out is before the crash, not afterwards.
Jose
idea: single occupant VTOLs.. (will it fly?) Eddie Home Built 5 April 20th 04 03:05 PM
A Brilliant Idea nafod40 Home Built 4 September 9th 03 10:33 PM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
What's wrong with this idea? Ace Pilot Piloting 28 August 13th 03 03:51 PM
