Hi,
I have a quite stupied question - I am sorry... If an aerobatic program dictates a 360 degree inverted turn to the left.... will that be a left circle when viewed from the ground ie. right rudder left stick ? I tried to look it up in the "IAC Official Contest Rules" but I can't seem to find it... Best regards Some rules-novice |
will that be a left circle when viewed from the ground ie. right rudder left stick ? I tried to look it up in the "IAC Official Contest Rules" but I can't seem to find it... Neither....or either. The direction of turn is up to the pilot, as long as he ends up going the right direction. So you'd probably make the 360 in the direction of the most open box, just to reduce the liklihood of going "out". Similarly, 90 and 270 degree turns from the X (main) axis to the Y axis may be made either way, so you choose based on other needs such as positioning the next figure, not going out, wind direction, etc. 90 and 270 turns FROM the Y axis TO the X axis must be made in whatever direction results in your heading the correct direction once you're back on the X axis. The Aresti symbols for rolls and spins are also non-directional. However, if there are consecutive roll symbols on a figure, they'll be either "same" or "opposite" and must be so flown. Spins and vertical (up or down) rolls must result in going the direction you want (or need) to go, and the "same" and "opposite" concepts hold true also. Otherwise the symbols are non-directional. If there's a looping figure between rolls in a figure, for example a roll, half loop up, then half roll, the roll directions don't affect each other. Similarly a roll up on a hammer or humpty, and a roll down. Either can be made either direction, subject to the need to be going the right direction when you're done. Doug Sowder |
Dear Sir,
Thank you for the explanation, I am very glad you took the time to explain it in such detail. Best regards "DSowder" wrote in message ... If an aerobatic program dictates a 360 degree inverted turn to the left.... will that be a left circle when viewed from the ground ie. right rudder left stick ? I tried to look it up in the "IAC Official Contest Rules" but I can't seem to find it... Neither....or either. The direction of turn is up to the pilot, as long as he ends up going the right direction. So you'd probably make the 360 in the direction of the most open box, just to reduce the liklihood of going "out". Similarly, 90 and 270 degree turns from the X (main) axis to the Y axis may be made either way, so you choose based on other needs such as positioning the next figure, not going out, wind direction, etc. 90 and 270 turns FROM the Y axis TO the X axis must be made in whatever direction results in your heading the correct direction once you're back on the X axis. The Aresti symbols for rolls and spins are also non-directional. However, if there are consecutive roll symbols on a figure, they'll be either "same" or "opposite" and must be so flown. Spins and vertical (up or down) rolls must result in going the direction you want (or need) to go, and the "same" and "opposite" concepts hold true also. Otherwise the symbols are non-directional. If there's a looping figure between rolls in a figure, for example a roll, half loop up, then half roll, the roll directions don't affect each other. Similarly a roll up on a hammer or humpty, and a roll down. Either can be made either direction, subject to the need to be going the right direction when you're done. Doug Sowder |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 03:32 PM |
Boeing 757 turn rate? | Garyurbach | Aerobatics | 6 | June 14th 04 04:43 PM |
Calculating vertical time and distance in a stall turn (US Hammerhead) | Dave | Aerobatics | 3 | November 20th 03 10:48 AM |
