I am building and ready to register a Europa experimental. I have
both regular and glider wings. I am soliciting opinions as to any problems or restrictions to flight if I register it as a motorglider. I see advantages as to no medical requirements for glider license, and also 10 flight requirement for license and a motor launch endorsement from a CFIG. Any opinions or comments welcome Thanks........ |
Russ Haggerty wrote:
I am building and ready to register a Europa experimental. I have both regular and glider wings. I am soliciting opinions as to any problems or restrictions to flight if I register it as a motorglider. I see advantages as to no medical requirements for glider license, and also 10 flight requirement for license and a motor launch endorsement from a CFIG. Any opinions or comments welcome Thanks........ Glider and Lighter-Than-Air pilots do have medical requirements. However, they don't have to hire an AME to certify the pilot has no concition that would make him unsafe. These pilots are "self certifying." |
On Sat, 13 Nov 2004 12:38:29 GMT, Russ Haggerty
wrote in :: I am building and ready to register a Europa experimental. I have both regular and glider wings. I am soliciting opinions as to any problems or restrictions to flight if I register it as a motorglider. I see advantages as to no medical requirements for glider license, and also 10 flight requirement for license and a motor launch endorsement from a CFIG. Any opinions or comments welcome Thanks........ Congratulations on your completion of a worthy project. In addition to the benefit of self-certifying your medical condition for operation of your Europa, registering it as a motorglider will give you the right-of-way over all but balloons, aircraft in distress, and perhaps aircraft towing or refueling other aircraft. I am unable to think of a single negative aspect to choosing to register your Europa as a glider. I've crossposted to rec.aviation.soaring; readership of that newsgroup may be able to provide additional insight into your decision. What are other Europa builders doing? http://ecfr.gpoaccess.gov/cgi/t/text....2.4.7&idno=14 § 91.113 Right-of-way rules: Except water operations. (a) Inapplicability. This section does not apply to the operation of an aircraft on water. (b) General. When weather conditions permit, regardless of whether an operation is conducted under instrument flight rules or visual flight rules, vigilance shall be maintained by each person operating an aircraft so as to see and avoid other aircraft. When a rule of this section gives another aircraft the right-of-way, the pilot shall give way to that aircraft and may not pass over, under, or ahead of it unless well clear. (c) In distress. An aircraft in distress has the right-of-way over all other air traffic. (d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories— (1) A balloon has the right-of-way over any other category of aircraft; (2) A glider has the right-of-way over an airship, powered parachute, weight-shift-control aircraft, airplane, or rotorcraft. (3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft. However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft. ... |
One reason to register as a glider is that it may be more valuable on sale,
because of the medical issue. Right now, a pilot who has been denied a medical may not be licensed under the new sport-pilot rules, but can fly a glider/motorglider so long as he can certify himself. One caution is that once certified as an aircraft, it may be difficult to recertify it as a glider. So, if you think you may ever want it certified as a glider, then do it with the original certification. Colin N12HS --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.783 / Virus Database: 529 - Release Date: 10/25/04 |
Larry Dighera wrote:
I am unable to think of a single negative aspect to choosing to register your Europa as a glider. The vast majority of pilots have an airplane license and NOT a glider license (in the USA). They will not be able to get insurance without at least a glider solo endorsement and a self-launch endorsement. There are at least 100 ASEL CFIs to every self-launch capable CFIG, so finding an instructor is difficult even if you provide the Europa for training for free prior to purchase. So if you decide to get a partner or sell the aircraft, you will either have a smaller pool of potential interested pilots, or will have to convince interested parties to take glider training. Whether this negative is overriden by other positives is something you'll have to consider... I wish the USA would instantly grant glider privs. to every airplane pilot. Then the only thing stopping a pilot from flying a glider would be the need for a launch endorsement. I've never met an ASEL pilot who couldn't safely fly a glider in all the other areas by the time he had learned to safely aerotow... -- ------------+ Mark J. Boyd |
In article . net,
COLIN LAMB wrote: One reason to register as a glider is that it may be more valuable on sale, because of the medical issue. Right now, a pilot who has been denied a medical may not be licensed under the new sport-pilot rules, but can fly a glider/motorglider so long as he can certify himself. The Europa Vne is so high it would not qualify as a glider under sport pilot. If the max cruise is low enough, it may qualify as a Light Sport Airplane, however, with all the advantages of minimal maint. certification and no medical... Anyone know the Europa max cruise speed in level flight? -- ------------+ Mark J. Boyd |
Doesn't need to. It would be certified as a glider, experimental, amateur
built. There is no category for motorglider. It would not be subject to weight, speed limitations, other than what you put down on the certification papers when you get it certified. Builder's choice. Mark James Boyd wrote in message 41964365$1@darkstar... In article . net, COLIN LAMB wrote: One reason to register as a glider is that it may be more valuable on sale, because of the medical issue. Right now, a pilot who has been denied a medical may not be licensed under the new sport-pilot rules, but can fly a glider/motorglider so long as he can certify himself. The Europa Vne is so high it would not qualify as a glider under sport pilot. If the max cruise is low enough, it may qualify as a Light Sport Airplane, however, with all the advantages of minimal maint. certification and no medical... Anyone know the Europa max cruise speed in level flight? -- ------------+ Mark J. Boyd |
"Mark James Boyd" wrote in message news:4196428a$1@darkstar... I've never met an ASEL pilot who couldn't safely fly a glider in all the other areas by the time he had learned to safely aerotow... Then you are just lucky. Vaughn |
One caution is that once certified as an aircraft, it may be difficult to recertify it as a glider. So, if you think you may ever want it certified as a glider, then do it with the original certification. Colin N12HS An Airplane and a Glider are both AIRCRAFT... so how do you intend to certify it? I think you meant to say, Airplane,, not Aircraft.. and yes.. once certified one way, it is difficult to change... BT |
| Thread Tools | |
| Display Modes | |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 04:13 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 03:31 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
