Cleaning up a reamed hole?
Old March 24th 04, 03:35 PM
Boelkowj
Default Cleaning up a reamed hole?
Can anyone advise me how I should clean up a 5/16th reamed aluminum hole to
eliminate stress fractures. Is the process called "burnishing" and how is it
done? Will fine grade sandpaper work. This is an important wing fitting.
Thanks.
Larry
Old March 24th 04, 05:11 PM
Kyle Boatright
"Boelkowj" wrote in message
to
it
Thanks.
Larry
Other than deburring the edges, I wouldn't do any further work to a reamed
hole. It should be very smooth in the first place.
KB
Old March 24th 04, 05:17 PM
Richard Lamb
to
it
Thanks.
Larry
KB
Yeah. If you are at final size hole and have detectable cracks,
Doitover....
Old March 24th 04, 07:23 PM
Boelkowj
KB: I haven't done the job yet. But thought burnishing/cleaning up the hole was
SOP even if the hole looked smooth and almost perfect.
Larry
Old March 24th 04, 08:17 PM
Veeduber
Normally, reaming is the final step in preparing a hole to accept a fastener.
Any chamfering is done prior to the final reaming.
Assuming there are no visually apparent flaws, with parallel-sided holes the
quality of any hole is relative to the fit of the fastener. There are four
general catagories of fit: Free, light press, driven, and shrunk.
'Burnishing' has several interpretations with regard to holes and varies
according to the application. At one time it was common practice to knurl an
oversized hole then swage it back to spec using a hardened dowel. But such
practices are not used in aircraft.
-R.S.Hoover
Cleaning up brushes/dope? Michael Horowitz Home Built 5 June 23rd 11 02:11 AM
Cleaning the sprayer Michael Horowitz Home Built 2 August 26th 03 03:12 AM
Fairing question... Tina Marie Home Built 5 July 16th 03 12:18 AM
