Can GPS be *too* accurate? Do I need some XTE??
Old November 18th 04, 12:48 AM
Icebound
Default Can GPS be *too* accurate? Do I need some XTE??
In the "good old" VOR days, it must have been pretty difficult to fly down
the centerline of an airway (or of any direct track).
So an eastbound VFR/IFR aircraft descending from 7500/7000 to his
destination, was more than likely to avoid traffic... on the reciprocal
track passing him by at 6500 or 6000... by some significant horizontal
error-distance, even if they didn't see each other (big sky theory :-) ).
GPS horizontal accuracy with WAAS is already in the order of magnitude of a
Cessna's wingspan, and some are talking about getting it down to mere
inches.
So the question is: If my Westbound Cessna at 6000 feet (with the autopilot
keeping it happily on the GPS-track centerline) meets the descending Bonanza
on the reciprocal track between the same two airports (using a similar
GPS/a-p combo), there is a distinct possibility that the horizontal
clearance may be zero...
....so is there anything in the current crop of GPS and/or Autopilot systems
that allow me to maintain a small cross-track error of my choosing, without
actually entering off-navaid-off-airport waypoints? ...or do we care; am I
overly concerned???
Old November 18th 04, 01:44 AM
Peter Duniho
"Icebound" wrote in message
systems that allow me to maintain a small cross-track error of my
choosing, without actually entering off-navaid-off-airport waypoints?
...or do we care; am I overly concerned?
You are not overly concerned, it does present a greater chance of a
collision.
I haven't heard of a GPS unit that allows the user to set some sort of
"offset" from a course to follow, but it wouldn't surprise if such a feature
did exist somewhere.
Beyond that, the "big sky theory" still works reasonably well. Two
airplanes in level flight on opposite headings on the same airway stand a
decently improved chance of running into each other if they are using GPS.
But when at least one is climbing, they share their altitude for such a
short period of time, I would think that the *actual* risk is relatively
low, even if the GPS does significantly increase the risk when compared to a
VOR receiver.
In any case, even before GPS it was still reasonably important to be alert
for other traffic while traveling on airways (even beyond the general
importance of doing so at all times). GPS increases the risk, but the risk
was always there and I've certainly had my share of close encounters (under
1 mile) flying on airways with a VOR receiver.
Pete
Old November 18th 04, 01:50 AM
Roy Smith
The CNX-80 / GNS-480 has it. It's called "Parallel Track". You tell it
if you want to fly left or right of course and by how much (in 1/10's of
a mile IIRC), and it invents a new course line for you to follow.
I believe the Apollo GX-60 had it too. The story I heard was the CAP
wanted to buy a bunch of GX-60's, but insisted Apollo add the Parallel
Track feature to facilitate flying grid search patterns.
Old November 18th 04, 04:21 AM
Fox Hound
feature
Parallel track and the grid search feature are not related to each other.
The GX series has the search grid lines on its display so CAP pilots can
stay oriented in their search grid. But even that wasn't as useful because
the grid lines they did show were not at the correct level. IIRC, you want
7.5 minute grid lines and the GX only showed down to 15 minute grid lines.
Old November 18th 04, 08:17 AM
Stan Gosnell
Roy Smith wrote in
of "offset" from a course to follow, but it wouldn't surprise if such
a feature did exist somewhere.
it if you want to fly left or right of course and by how much (in
1/10's of a mile IIRC), and it invents a new course line for you to
follow.
The Trimble 2102 has it, and so do most other units.
Regards,
Stan
Old November 18th 04, 09:56 AM
Do you know whether the Garmin 400/500 series (other than the 480) have it?
Old November 18th 04, 03:28 PM
Jose
[how and whether to fly an offset on a GPS track]
Just hand fly. You can hand fly any offset you like.
Jose
Freedom. It seemed like a good idea at the time.
Old November 18th 04, 03:37 AM
Stan Prevost
"Peter Duniho" wrote in message
My Northstar M3 has parallel track offset, as does the GX-60
Old November 18th 04, 02:01 AM
John R. Copeland
"Icebound" wrote in message =
=20
So the question is: If my Westbound Cessna at 6000 feet (with the =
autopilot=20
keeping it happily on the GPS-track centerline) meets the descending =
Bonanza=20
on the reciprocal track between the same two airports (using a similar =
GPS/a-p combo), there is a distinct possibility that the horizontal=20
The July 2004 issue of "International Procedures News" from
Flight Safety Inc., carried an item exactly about that,
in regard to the North Atlantic routes.
Here is one paragraph, which I quote from that article:
"Following a successful trial in the West Atlantic Route System (WATRS),
it has been determined that by allowing aircraft conducting oceanic =
flights
to fly lateral offsets not exceeding two NM right of centerline,
an additional safety margin will be provided and will mitigate the risk
of collision when non-normal events such as operational altitude =
deviation errors
and turbulence induced altitude deviations occur."
The remainder of the article describes the 1-nm or 2-nm offsets allowed,
and only to the right of centerline, with effective date of June 10, =
2004.
The name of this concept is "Strategic Lateral Offset Procedure",
so everyone can understand they've now added SLOP to the route system!
As Dave Barry might say, I am not making this up.
---JRC---
Old November 18th 04, 09:48 AM
"John R. Copeland" wrote:
"Icebound" wrote in message ...
and only to the right of centerline, with effective date of June 10, 2004.
---JRC---
Keep in mind those offsets are in oceanic airspace where the route width is 25 or 30 miles, centerline to
edge. Along a domestic airway, offsets of those magnitude would be far too large. An offset of 1/10 of a
mile would probably be effective without creating an issue with compliance with FAR 91.189. (although the feds
might not buy that rationale ;-)
Can GPS be *too* accurate? Do I need some XTE?? Icebound Instrument Flight Rules 82 November 22nd 04 08:01 PM
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
How accurate was B-26 bombing? ArtKramr Military Aviation 59 March 3rd 04 10:10 PM
Local TV News ran an accurate story about airframe icing last night Peter R. Piloting 5 January 29th 04 01:01 AM
VOR and reverse sensing Koopas Ly Piloting 40 August 25th 03 01:26 AM
