Solution To Newton's Third Law of Motion.
Old November 18th 04, 11:29 PM
Jeet
Default Solution To Newton's Third Law of Motion.
Hello, I am back.
http://www.geocities.com/abhi_yaan
I built this action device for generating unidirectional force for
reactionless propulsion of body. As everybody knows, loss of matter is
the problem with Newton's third law of motion. We have sources of
energy like sun out there in space. But we just can't use solar power
to give thrust to spaceship. There should be some mechanism to use
pure energy to give thrust to a body without pushing or expelling any
reaction mass.
So I built this device and yesterday tested this device. I used two
rod, wooden platform as rolling seat. I put this rolling seat on cot
and using this device I succeeded moving the cot on ground. The device
is working because I have not pushed or expellled any mass to push the
cot. I was sitting on rolling seat on cot. So the device works.
But today, I noticed that I am sitting on this rolling seat on cot and
pulled one end of cot with just "my both hands" with *sudden surge of
force* and cot moved on floor. This should not happen. If I pull the
cot slowly, it will not move. I also noticed that even without rolling
seat, simply sitting on cot, if I give sudden surge of force to cot,
cot moves on floor. Due to friction of my body with cot, this should
not happen.
Believe me, I have pushed the cot for about a feet on ground just
sitting on rolling platform on cot. I didn't used any reaction mass.
I thought that something is wrong and I must return to basic. If I
pull wall, wall also pulls me. In reality, due to friction of our leg
with ground, our body seldom moves towards wall. But if we use
frictionless surface or rolling surface, then if we pull wall, wall
also pulls our body. Tested by millions.
I am standing on this rolling platform. If I pull wall slowly, wall
also pulls me and my whole body moves towards wall.
But if I pull the wall towards me with "sudden surge of force", then
even if I am standing on rolling platform, my body does not move at
all.
This is 26th month thinking on Newton's third law of motion day and
night. I have suffered so much.
What the hell is going on? We can propel a body without
pushing/expelling any reaction mass and we can do it by simply giving
"sudden surge of force by our hand" to a body. That body gains
momentum and due to momentum of that body, we, source of sudden surge
of force, also moves in direction of motion of body because of
momentum of that body. No loss of matter, no expulsion of reaction
mass.
Solution to Newton's third law of motion: *Sudden Surge of Force*?
-Abhi.
Old November 19th 04, 12:17 AM
Uncle Al
Jeet wrote:
Hello, I am back.
[snip]
Your ignorance, incompetence, and psychosis are not of interest to the
world at large. Quite the contrary. You are not even an interesting
laughingstock.
You see yourself this way,
http://www.mazepath.com/uncleal/effete6.jpg
The entire remainder of the planet sees you this way,
http://www.mazepath.com/uncleal/effete3.png
Uncle Al
(Toxic URL! Unsafe for children and most mammals)
http://www.mazepath.com/uncleal/qz.pdf
Old November 19th 04, 04:35 AM
Jeet wrote:
Hello, I am back.
Really?
I wouldn't call it a problem.
We have sources of
Why not? You just put out a sail that reflects photons
backwards. That will push you forward. The photons
are reacting. The sun doesn't have to.
John Anderson
Old November 20th 04, 02:06 AM
AaronB
(Jeet) wrote in message om...
Hello, I am back.
Loss of matter is not a problem.
We have sources of
Try some solar panels for your engine.
reaction mass.
"Pure" energy does not exist. Energy is an abstract quantity.
This is a standard application of Newton's Third law. The force you
are exerting to *try* to move the platform may not be enough to
overcome the friction force between you and the cot; but if the
friction force between the cot and the ground is small, the
reactionary force can certainly cause the cot to accelerate forward.
not happen.
If you push the cot, of course it should move.
I think you're misunderstanding how Newton's Third Law works. Newton's
third law states: If object A exerts a force on object B, then object
B exerts an equal force in the opposite direction on object A. The
masses of the objects, nor the loss of mass, are not necessarily
relavent
If you push the wall, the wall pushes back. Think about being on a
skating rink. If you push away from the wall, you move away from it,
not toward it.
But if we use
Yes.
If there was a handle on the wall or something, and you pulled it,
then yes, you would move toward the wall. If you push the wall, you
will move away.
all.
Ah, I see now. You're confused about kinetic and static friction. Let
me explain. Static friction is used for stationary objects. If you
push on something, and can't get it to move, you're fighting static
friction (also, incidentally, if you are are pushing something, and it
ROLLS, this is also static friction), if on the other hand, an object
is already in motion (but not rolling) then you are fighting kinetic
friction. Kinetic friction is not as strong as static, which is why it
is always hardest to get something moving, rather than to keep it
moving. The effect you are describing is that when you try to
accelerate something to roll with a large force, you will overcome
static friction almost immediately, and it will not roll, but SLIP.
For a rolling object, it will probably not move as much as if you
rolled it normally. Think of it this way: there's an old parlour trick
where you place a bunch of glasses and stuff on a table with a
tablecloth. If you pull off the tablecloth slowly, the glasses will
all fall; if you pull it off quickly, the glasses will (probably)
remain standing. With enough practice.
Try taking an introductory course on classical mechanics. Or get a
textbook.
mass.
Loss of matter is not required.
Solution to Newton's third law: If object A exerts a force on object
B, then object B exerts an equal force in the opposite direction on
object A.
A.
-Abhi.
Old November 20th 04, 09:34 PM
On 18 Nov 2004 15:29:25 -0800, (Jeet)
Hello, I am back.
reaction mass.
not happen.
all.
mass.
-Abhi.
Oh, God.
How's the implant?
Hardware and software for motion platform [email protected] Home Built 0 November 4th 04 10:57 PM
Weeks Solution and Weeks Special Mirco Aerobatics 0 October 2nd 04 04:11 PM
OPINIONS: THE SOLUTION ArtKramr Military Aviation 4 January 7th 04 10:43 PM
Low Cost Motion Simulators For PC Games!!!! Mark Barry Military Aviation 0 December 19th 03 03:37 AM
Full motion home flight simulator. The Enlightenment Naval Aviation 10 November 25th 03 12:36 PM
