Did the PA-28-180....
Old December 21st 04, 01:18 AM
Casey Wilson
Default Did the PA-28-180....
.....have an option for a constant speed prop prior to 1975?
Old December 21st 04, 01:46 AM
Bob Noel
In article uRKxd.2426$2X6.28@trnddc07,
Not from Piper.
Bob Noel
looking for a sig the lawyers will like
Old December 21st 04, 04:13 AM
Nathan Young
On Tue, 21 Dec 2004 01:18:18 GMT, "Casey Wilson"
No.
There are aftermarket conversions for the -A3A engines that have the
hollow crank shaft.
MT-Propellers has an STC for an electric (3-bladed?) CS prop.
Old December 22nd 04, 05:46 AM
aluckyguess
How many knots would be gained with this?
"Nathan Young" wrote in message
No.
hollow crank shaft.
Old December 23rd 04, 04:33 PM
Nathan Young
The consensus is little top end would be gained, although a few
additional knots would be possible by allowing the engine to operate
at higher power at lower altitudes.
See this google thread for a discussion on fixed pitch vs. C/S.
http://makeashorterlink.com/?Y5531281A
Old December 24th 04, 08:36 AM
Marty
"aluckyguess" wrote in message
Hi Lucky,
Congrats on the license!
Think of a CS propeller as an overdrive. Simply, it's purpose is to lower
the fuel consumption by taking a bigger bite of air in cruise. You basically
get the same cruise speed for less rpms.
Properly used, a CS prop also helps to maximize engine life. Improper or
misuse of a CS prop can render even a new airplane to glider status
quickly,especially turbo equipped aircraft.
There are other benefits and caveats, you will learn them if you go for a
complex endorsement.
HTH,
Marty
Old December 25th 04, 12:56 AM
aluckyguess
"Marty" wrote in message
Hi Lucky,
basically get the same cruise speed for less rpms.
HTH,
Marty
Thanks
