3-point landings
Old December 25th 04, 08:17 AM
Ramapriya
Default 3-point landings
While we were awaiting takeoff clearance at Khartoum recently, an
Ilyushin IL76 Syrian Air cargo plane landed. Just prior to touchdown,
it kinda flattened out from its nose-down final and clearly did a
3-point landing. I was looking at the plane from my starboard window
seat.
During flight, I had an opportunity to talk up our plane's First
Officer (a Syrian, incidentally). When I mentioned the lack of a flare
in the Ilyushin's touchdown, he said he'd seen it too but wasn't unsure
that it might have made a mini-flare which we may not have caught from
our distance of about 75 meters out.
Has anyone here piloted an IL76 often enough to know whether or not it
can indeed do a 3-point landing?
Cheers,
Ramapriya
Old December 25th 04, 05:06 PM
Bob Moore
Any jetliner that is landed too fast will touchdown in a
flat attitude...not very desireable though. Jets are not
"flared" for touchdown in the same sense as we do in small
private planes. Unlike "Cessnas", a jet at normal approach
speed will have a positive attitude which means that the
nosewheel is higher than the main wheels, this is the desired
attitude for touchdown. Most often, the pilot simply raises
the nose a couple of degrees to break the rate of descent
and then put it back where it was for touchdown. The FAA
really frowns on "hold-it-off","nose-high" touchdowns.
Bob Moore
CFI ATP B-707 B-727
Old December 25th 04, 05:34 PM
Jose
[for jetliners] The FAA
Why?
Jose
Freedom. It seemed like a good idea at the time.
Old December 25th 04, 06:00 PM
Bob Moore
Jose wrote
The FAA really frowns on "hold-it-off","nose-high" touchdowns
Why?
The airplane will decellerate much better on the ground than
when "floating" or being "held-off".
The flight procedures that the FAA require the airlines to
develope for their flightcrews assume that each takeoff and
landing will be made on the minimum runway required by the
aircraft performance manual. No room for that squeeker.
Bob Moore
Old December 25th 04, 06:09 PM
Ramapriya
What and who did you reply, mate? )
Ramapriya
Old December 25th 04, 11:22 PM
G.R. Patterson III
seat.
I worked on the expansion of Hartsfield back in the late 80s. The Piedmont 737
FLUFs used to make similar approaches. They would basically come in in a dive,
level off just above the runway, and touch down. The nosewheel would definitely
be off the ground at touchdown, though, but not by much.
I guessed at the time that the pilots used that approach because Piedmont flew
into a lot of fairly short fields (like Asheville). Years later, I had an
opportunity to talk with a high-time retired 737 pilot. He stated that that type
of approach was commonly used for short fields, especially ones with obstacles
(which defines Asheville real well). I assume that Piedmont just used it for
every airport as SOP.
Never saw any other airline bring in 737s that way. Never saw a Piedmont 737
landed any other way.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old December 25th 04, 11:23 PM
G.R. Patterson III
He quoted part of Bob Moore's post. Perhaps Bob's didn't arrive on your server
yet?
George Patterson
Old December 26th 04, 12:29 AM
G.R. Patterson III
70s
George Patterson
Old December 26th 04, 04:24 AM
I've never heard of the FAA having an opinion about that. The
technique probably has more to do with practicalities than regulations.
Brakes, thrust reversers, spoilers and other lift dump devices all help
airplanes stop.
On most jets these devices don't start working until the wheels hit the
ground. So getting wheels on the ground quickly works better. But
with excess runway hold-it-off greasers are possible and even
desireable in some cases.
Alex
Old December 27th 04, 02:09 PM
Peter R.
G.R. Patterson III ) wrote:
The Piedmont 737 FLUFs
What's a FLUF? Is it similar to a FLIB (the term of endearment used by
ATC when describing small GA aircraft)?
Peter
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
Night landings vs. day landings Gerald Sylvester Piloting 15 February 12th 04 06:38 AM
Power-out spot landing techniques? Richard Thomas Piloting 50 August 20th 03 01:27 AM
