Thermal Conductivity , Ice & Me (or You, too)
Old February 11th 05, 06:19 PM
Montblack
Default Thermal Conductivity , Ice & Me (or You, too)
(Greenwavepilot, the OP, just posted this over on rec.aviation.student)
You are missing something. I typed the wrong temperature. The overnight low
was 30*F, not 40. So, it WAS below freezing for a period of time.
So one mystery is solved.
Now about those black wings at night...
Montblack
Old February 11th 05, 09:50 PM
greenwavepilot
Thanks for bringing this over Montblack. I really wish I would have
caught my typo because I think it pulled away from my main
point/question, which is, "What is the difference in thermal
conductivity (as it relates to ice/icing conditions) between a
composite wing and an aluminum wing."
Obviously, at certain extreme temperatures and conditions (NH in
January), both an aluminum and composite wing may act similarly, or in
other words, the therrmal conductivity/icing differences may not be
distinguishable.
But in marginal temperatures and conditions, (like SC in February),
those differences MAY be quite distinguishable, as the experience I
posted, and may be a point of concern for composite drivers.
Or I may be completely bonkers. But the only logical explanation I
could reason/infer from my experience was that the thermal conductivity
differences between aluminum and fiberglass were to blame.
This probably breaches usenet protocol, but I shall reprint my original
post from r.a.student that Montblack refers to below, with the
temperature typo corrected.
"I am training in a Diamond DA-20 C1, incidentally, the only
composite airplane on my flight schools ramp. I am flying in upstate
SC. This morning, at 8:15 the top surfaces of the wings on the C1 were
iced significantly, as was the nose and fuselage (tail boom). Outside
air temp was 41*F/Overnight low was 30*F. Plane is tied-down, morning
sun was directly on wing surfaces, no intervening shadows. My lesson
was delayed, of course.
Curious, I checked the other planes on the ramp-all of which are
aluminum. NONE had icing on any surface. Through a very unscientific
"hand touch" test I determined the composite surfaces "felt" much
colder than the aluminum surfaces.
I would be very interested in learning more about the heat/cold
transfer dynamics of aluminum versus composites. Pure speculatin'
though, I would bet from my limited experience that the composite will
ice faster or retain ice longer than similarly exposed aluminum. But,
there's always someone who knows more about it than me-so maybe they
will chime in.
So, I did some research and found the following thermal
conductivity values (Note these figures are for a standard temperature
of 25*C):
Aluminum,
Pure=237 watts/meter*Kelvin
Fiberglass,
Paper Faced=.046 watts/meter*Kelvin
So, what I should have inferred from my non-aviation experience with
these materials is confirmed by the above thermal conductivity values.
That is, aluminum is a good heat conductor-it can either gain or lose
heat very quickly. Fiberglass on the other hand is a good insulator.
It does not lose or gain heat very rapidly. Thus once "set" at a
temperature, it will tend to remain there longer than aluminum.
Therefore versus fiberglass the aluminum surfaces
will cool to icing temperatures faster, and conversely will heat to
non-icing temperatures faster. The composite will cool more slowly,
but once cooled, will retain that temperature much longer, meaning like
I discovered this morning, my composite plane will/may be iced when the
Cessnas, Pipers and Mooneys won't.
During the preflight "Hand Checking Of All Surfaces" has added meaning
for a composite driver (especially one like me who has scheduled 8am
lessons so that I can at least pretend there is a usable workday
left.
WPR
Student Pilot"
Old February 12th 05, 12:12 AM
Larry Dighera
On 11 Feb 2005 13:50:34 -0800, "greenwavepilot"
wrote in
. com::
Yes, exactly.
Consider also, the mass of composite v aluminum necessary to achieve
the same strength. I'd guess the composite skin thickness exceeds
that of the aluminum skin.
Old February 12th 05, 02:24 AM
Steve.T
The composite materials are used as insulation in certain cases. Think
of fiberglass.
Next, look at the paint used for the a/c in question. The composites
are painted below the surface while the metal a/c have painted
surfaces.
Now, given the insulative qualities of the composites, and the surface
area with which to "absorb" energy (heat), the aluminum a/c will shed
ice much faster when placed in a heated hanger than will a composite.
Now if you place a fan in that heated hanger, the composite will de-ice
at a faster rate.
OTOH - at altitude and with air speed, I do not know if the composite
will ice faster than the aluminum, because the aluminum is not (well, I
wouldn't think it) as smooth as the composite. So water has something
to adhere to which will start the process (talking about rime). Because
of the smoothness of the wing, I don't know, and have no experience
with clear ice and its ability to stick to the wing. But because my
step-son is close to test flying his Vari-eze (I think that is the one
he is building), we may be able to find out by this time next year.
So you other composite drivers, how about practical experience?
Later,
Steve.T
PP ASEL/Instrument
Old February 12th 05, 03:08 AM
George Patterson
of fiberglass.
Fiberglass, in and of itself, is not a particularly good insulator. When it's
spun into a sort of glass wool and traps a lot of small air bubbles, that
changes. The air *is* a good insulator.
George Patterson
He who would distinguish what is true from what is false must have an
adequate understanding of truth and falsehood.
Old February 12th 05, 05:18 AM
Casey Wilson
"George Patterson" wrote in message
of fiberglass.
it's
Depends on how you look at it. In the long-wavelength infrared
spectra the atmosphere is virtually transparent. In that regard, air is an
excellent conductor since it poses no resistance to thermal radiation. And
it is the radiation that accounts for the type of heat loss involved in
these discussions, not conduction. So it is the thermal emissivity of the
wing surface that really matters -- not the molecular conductivity.
Old February 12th 05, 09:06 AM
Larry Dighera
On Sat, 12 Feb 2005 05:18:37 GMT, "Casey Wilson" N2310D @ gmail.com
wrote in NkgPd.2805$uc.202@trnddc01::
If the molecular conductivity is unimportant, once the surface changes
temperature, how does the rest of the material change temperature
without conduction?
Old February 13th 05, 04:34 AM
Casey Wilson
"Larry Dighera" wrote in message
without conduction?
Go back and read it in context. I didn't say there was no conduction.
What I said was (in different words) that conduction is not the process of
the wing surface losing thermal energy. Here, I'll put it in another term so
you can do some more nit picking: Because the atomosphere is transparent in
certain important wavelengths, the heat of the wing is being sucked into
outer space.
For Auction: Thermal Imaging Camera - One Day Left sell2all Naval Aviation 0 April 29th 04 08:09 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all General Aviation 0 April 29th 04 08:09 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all Military Aviation 0 April 29th 04 06:45 PM
For Auction: Thermal Imaging Camera - One Day Left sell2all Home Built 0 April 29th 04 06:43 PM
FA: Raytheon Thermal Imaging Camera - Very Nice! Michael J. Military Aviation 0 April 21st 04 11:23 PM
