Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
need advice
Old January 5th 04, 02:54 AM
benmen
Default need advice
need help on decision oppolo 80/ mx20 or garmin 430/530 and what is
the differents between the two
Old February 8th 04, 04:47 AM
carlos
From what I learned during my search for a multi function display:
The 80/MX20 combo is much newer than the 430/530, thus it should be
technologically more advanced.
The MX20 (http://www.garmin.com/products/mx20/) screen is wonderful to look
at, with more colors and resolution. The CNX-80
(http://www.garmin.com/products/cnx80/) also has a better screen than the
430/530 (http://www.garmin.com/products/gns530/) and is usually highly
recommended as a combo with the MX20
(http://www.garmin.com/products/cnx80/mx20Pop.html). The CNX-80 is WAAS
approved for precision GPS approaches as well.
However, the MX20 has no GPS/COM/NAV... It's just a display for your other
equipment. It does great things, such as split screens, and relative terrain
mapping (it color codes terrain according to your current altitude).
If you went with a Garmin 530 and a 430 you would have two GPS, two radios
and two NAVs, whereas with the CNX-80/MX20 you only have one of each.
I've heard the Garmin radios in the 430/530 are very underpowered compared
to, say, a King KX-155 - so you would have to be nearer your destination to
listen/transmit. This is why Garmin now offers a "A" version, which has more
power.
If I had to choose between a CNX-80/MX20 or a 430/530, I would probably go
with the CNX-80/MX20 only because it's newer and should offer more in the
long run. I'd throw in a KX-155 or equivalent as a second COM/NAV.
Check out this post for more info:
http://lists.kjsl.com/pipermail/beec...er/041264.html
Just my opinion - remember I have less than 100 hours flying... :-)
Regards,
CGP.
"benmen" wrote in message
Old February 8th 04, 01:10 PM
Abafon Goula
Carlos, good interpretation and probably correct for the most part.
I've never heard any problems about low powered panel mount radios
being a detriment, unless you're crossing the oceans. Remember, with
avionics, all it takes is money. And look at the Garmin 1000.
On Sun, 8 Feb 2004 00:47:46 -0400, "carlos"
power.
Regards,
CGP.
m...
Advice and experts with 400 series Cessnas (414 and 421), purchase and training [email protected] Owning 36 January 9th 05 02:32 AM
Seeking advice on pilot training approach... Rob General Aviation 8 December 15th 04 12:58 AM
Need advice on handling airplane damage GE Owning 24 November 11th 04 01:16 AM
boot camp advice jameson Military Aviation 17 July 22nd 04 05:12 AM
Advice Brad Piloting 9 October 28th 03 02:54 PM
