Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
FA: AnywhereMap Sentinel CF GPS
Old August 12th 04, 04:34 PM
Daniel Andresen
Default FA: AnywhereMap Sentinel CF GPS
I'm selling my Control Vision AnywhereMap Sentinel CompactFlash GPS on
eBay after going to a Bluetooth version. Works great.
Auction ends 8/14/04 at 3:12PM.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Specs:
The Anywhere Sentinel Compact Flash GPS is a powerful 12-channel SiRF
star IIe/LP low power chip set GPS that plugs directly into the
compact flash RAM slot on the PDA for up to 2 hours of operation on
iPAQ power alone. The new swivel top helps provide a better custom
view of the sky.
You can also use the Sentinel with a wide range of other portable
devices:
- Compaq iPaq Pocket PCs using Compact Flash Jacket for iPaq (or the
PC Card Jacket, with a PCMCIA adapter).
- HP Jornada 560-series Pocket PCs, using the built-in CF Slot.
- PCMCIA-enabled Laptops, with a PCMCIA Adapter.
Dimensions: 1 7/8" x 7/8" x 2 1/8"
Use the Sentinel with AnywhereMap software for PocketPCs or Notebooks
to create aviation's most powerful and most portable navigation
solution.
Add Pocket Streets Software (included with Microsoft's Streets & Trips
2002) and get the full benefit of GPS navigation even during those
times when you must drive there instead of flying.
Features:
- 12 parallel channel receiver.
- Wireless - Plugs into Compact flash slot.
- WAAS-enabled to enhance the accuracy of the GPS positioning.
- Swivel antenna head for optimal reception with built in antenna.
- Internal Lithium Battery.
- Powered by iPAQ PDA (Battery life 1-2 hours on iPAQ battery).
- Fast TTFF (Time To First Fix).
- Uses true NMEA data protocols.
- External Antenna included for use when necessary.
- Includes carrying case.
- Includes drivers, cables for serial & PS/2 connections
Old August 15th 04, 03:02 AM
Juan Jimenez
(Daniel Andresen) wrote in
m:
http://cgi.ebay.com/ebaymotors/ws/eB...rd=1&item=2486
591054&category=26436&sspagename=WDVW
Dang... missed it.
CVS AnyWhereMap in Eastern Oklahoma sidk Home Built 0 October 22nd 04 12:40 AM
CVS AnyWhereMap in Eastern Oklahoma sidk Piloting 0 October 22nd 04 12:40 AM
FA: AnywhereMap Sentinel CF GPS Daniel Andresen Aviation Marketplace 1 August 15th 04 03:02 AM
