Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
tachometer connection question
Old August 17th 03, 07:53 AM
Mike Marsh
Default tachometer connection question
I was just wondering if anyone knows what each pin (marked A, B, C) at
the rear of a G.E. type E-9A tachometer (serial no. AC42-65950)
connects to? I am assuming that the connections are similar to an
automotive tach, is that correct? Will trial/error testing hurt the
tach? I am trying to retrofit some P-51 gauges into my 1968 Mustang
(car), and could use any tech advice offered.
"They don't make 'em like they used to..."
Old August 17th 03, 03:23 PM
N329DF
unless your Mustang has a tach generator, it will not work. that system has no
power inputs, the generator creates a low voltage that is sent to the tach, the
tach is nothing more than a sychronis motor. Wiring is very simple, A to A, and
so on.
Matt Gunsch,
A&P,IA,Private Pilot
Riding member of the
Arizona Precision Motorcycle Drill Team
GWRRA,NRA,GOA
ISRAELI TORTURE CONNECTION: WHO IS JOHN ISRAEL? MORRIS434 Naval Aviation 0 May 12th 04 09:17 PM
ISRAELI TORTURE CONNECTION: WHO IS JOHN ISRAEL? MORRIS434 Military Aviation 0 May 12th 04 09:16 PM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT Naval Aviation 4 April 3rd 04 03:17 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT General Aviation 4 April 3rd 04 03:17 AM
When You Hear The Heavy Accent & The Poor Phone Connection... HANG UP!! ----- hithUOFT8mSo Aardvark G. Bandersnatch, CPE, RCA, IBM, LSMFT Owning 4 April 3rd 04 03:17 AM
