Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
IFR in the 1930's
Old August 30th 03, 01:40 AM
Del Rawlins
Default IFR in the 1930's
On 29 Aug 2003 01:15 PM, Dick posted the following:
Staring at my empty instrument panel while considering which
instruments and their placement, I got wondering how old time Mail
pilots flew if caught in IFR conditions.
Mostly, they flew into the ground.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old September 8th 03, 10:18 PM
A little flip, really sad but mostly true.
Del Rawlins-
Old September 11th 03, 04:49 AM
William T Bartlett
They flew very effectively on the Adcock range, which was set up across the
nation. This was a aural navigation system in which all that was necessary
was a tunable low freq radio, a watch, compas. and chart (some knowledge of
Morris code
"ADCOCK RANGE - National radio navigation system replaced after World War 2
by the omnirange system. It consisted of segmented quadrants broadcasting
Morse Code "A" (dot-dash) and "N" (dash-dot) signals in opposing quadrants
so that pilots could orient their position relative to a "beam" broadcasting
a steady tone, and a Morse Code station identifier. Using a "build-and-fade"
technique, a pilot could (ideally) pinpoint his location by the strength or
weakness of a signal"
look up adcock range on Goggle.DF was also available.
Bill
Del Rawlins-
Old September 11th 03, 05:08 AM
Dave Stadt
"William T Bartlett" wrote in message
of
Morris code
2
broadcasting
"build-and-fade"
or
Bill
That came long after the original airmail pilots and did absolutely nothing
to help them keep the dirty side down. Knowing where you are doesn't mean
much if you don't know which way is up. One tool they did use if caught on
top was to drop a parachute flare and follow it down through the soup hoping
they broke out before hitting the ground. If all else failed they hit the
silk.
Del Rawlins-
Old September 11th 03, 07:26 AM
Barnyard BOb --
On Thu, 11 Sep 2003 03:49:50 GMT, "William T Bartlett"
Morris code
big snip for obvious reasons
Bill
Bill..
Morris code?
Yeah, right.
Like Del said.....
They mostly flew into the ground.
Barnyard BOb - pre VOR pilot
Del Rawlins-
Old September 11th 03, 03:41 PM
Tim Ward
"Barnyard BOb --" wrote in message
necessary
of
Morris code
Bill
Bill..
Morris code?
Yeah, right.
Like Del said.....
Sure, Morris code. That's where you tie bells to your feet and communicate
by dancing.
Tim Ward
FS: 1930's Space Exploration Un-Cut Tatoo Sheet J.R. Sinclair Aviation Marketplace 0 June 7th 04 06:28 AM
1930s Navy side numbers. JDupre5762 Naval Aviation 3 September 24th 03 07:51 PM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
IFR in the 1930's Del Rawlins Owning 33 September 11th 03 07:42 PM
IFR in the 1930's Rich S. Owning 0 August 29th 03 11:59 PM
