Black Glareshield Felt
Old May 15th 14, 04:14 AM posted to rec.aviation.soaring
Echo
Default Black Glareshield Felt
Purchased some black "felt" at the local fabric store in preparation to felt my glare shield. Once I got the stuff outside the store in the sunlight, there appeared to be some sparkly polyester sheen to it. Any recommendations on type of fabric to kill glare?
Jordan
ASW20 E
Old May 15th 14, 05:17 AM posted to rec.aviation.soaring
Craig Funston
Jordan
ASW20 E
Real wool felt
Craig
Old May 15th 14, 06:30 AM posted to rec.aviation.soaring
CJ[_3_]
I've put the adhesive-backed felt that Richard/Craggy Aero sells to good
use. I'm happy with the outcome
B3
Real wool felt
Old May 15th 14, 02:25 PM posted to rec.aviation.soaring
Echo
Good to know, I'll check it out. Thanks
E
Old May 15th 14, 02:40 PM posted to rec.aviation.soaring
Andrew Brayer
E
real wool is the best way to go, but black velvety material works well too.
Old May 15th 14, 04:52 PM posted to rec.aviation.soaring
Bill D
Jordan
ASW20 E
Consider "Flocking".
http://en.wikipedia.org/wiki/Flocking_%28texture%29
If your glare shield is removable, you can take it to a local shop to have it done. It's better looking and more permanent than stick-on felt.
Old May 15th 14, 06:49 PM posted to rec.aviation.soaring
son_of_flubber
Flock it.
https://www.youtube.com/watch?v=PJFjorzlI3k
http://www.amazon.com/Suede-Tex-Floc...words=flocking
These guys also offer color matched spray glue.
Flocking conforms to irregular shapes.
Old May 15th 14, 07:15 PM posted to rec.aviation.soaring
Echo
Glareshield is off currently for a top mounted compass... What kind of stores do that?
Old May 15th 14, 07:51 PM posted to rec.aviation.soaring
Two Shoes (Judson Knowles)
Woodcraft sells this: http://www.woodcraft.com/category/4/.../Flocking.aspx
If you want to DIY
Old May 15th 14, 08:10 PM posted to rec.aviation.soaring
John Firth[_4_]
stores do that?
If you want to DIY
Aircraft Spruce / W and Wh sell acoustic soft rubber
mat black sheet; it will absorb some of the vent noise
too. 1/8 thick and very flexible.
JMF
Wool Felt for trailer fixtures now on Ebay Steve Koerner Soaring 10 April 12th 12 07:58 PM
PA-28 Glareshield Replacement Marco Leon[_4_] Owning 8 January 11th 08 08:33 PM
pressure-sensitive adhesive black felt bulk order? Frank[_1_] Soaring 5 July 26th 07 05:02 PM
Glareshield Overhaul? Mike Spera Owning 7 March 23rd 07 11:34 PM
Glareshield renewal and TSA Roger Long Owning 9 February 27th 04 12:39 PM
