How does a wet cloth really help (scientifically) to survive an airplane crash?
Old May 16th 14, 12:46 AM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
Ann Marie Brest
Default How does a wet cloth really help (scientifically) to survive an airplane crash?
I'm not sure WHERE to ask this, but, how does a wet cloth
work in an airplane crash anyway?
In step 3 at 45 seconds into this video shows it in use:
http://www.youtube.com/watch?v=RXaTt...etailpage#t=49
What's the wet cloth (scientifically) doing?
Old May 16th 14, 01:16 AM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
Frank[_16_]
Default How does a wet cloth really help (scientifically) to survivean airplane crash?
http://www.faa.gov/pilots/safety/pil.../Smoke_Web.pdf
Old May 16th 14, 04:26 AM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
Ann Marie Brest
Default How does a wet cloth really help (scientifically) to survive anairplane crash?
That nicely summarized FAA article explains:
- Smoke is a complex of particulate matter, invisible combustion gases & vapors suspended in the fire atmosphere.
- Inhalation of toxic gases in smoke is the primary cause of fatalities
- Carbon monoxide & hydrogen cyanide are the principal toxic combustion gases
- Carbon monoxide combines with the hemoglobin in blood and interferes with the oxygen supply to tissues
- Hydrogen cyanide inhibits oxygen utilization at the cellular level.
- Carbon dioxide is a relatively innocuous fire gas, increases respiration rate causing an increase in the uptake of other combustion gases
- Irritant gases, such as hydrogen chloride and acrolein, are generated from burning wire insulation
- Generally, carbon dioxide levels increase while oxygen concentrations decrease during fires.
And then finally, the article suggests:
- Cloth held over the nose and mouth will provide protection from smoke particulates;
- If the cloth is wet, it will also absorb most of the water-soluble gases (i.e., hydrogen cyanide & hydrogen chloride).
What's interesting is that the entire article doesn't discuss any dangers
of breathing smoke particulates, so, why it bothers to mention a dry cloth
is perplexing since we can safely assume that filtering out particulates is
merely a convenience, and not a safety issue.
So, now we're left with the a WET cloth absorbing water-soluble gases.
Of the two water-soluble gases, only hydrogen cyanide was listed in
the article as being a safety issue (the other water-soluble gas was
merely an irritant).
So, I guess we finally have the answer to "why the wet cloth?".
The WET CLOTH filters out (water soluble) hydrogen cyanide:
"Hydrogen cyanide poisoning signs & symptoms are weakness, dizziness, headache,
nausea, vomiting, coma, convulsions, & death. Death results from respiratory arrest.
Hydrogen cyanide gas acts rapidly. Symptoms & death can both occur quickly."
Old May 16th 14, 12:34 PM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
micky
On Fri, 16 May 2014 03:26:21 +0000 (UTC), Ann Marie Brest
Wow. That's good to have suggested. I certainly don't need any HCn or
HCl.
How can we safely assume that? I'd assume the opposite.
I think what you have is a 3-page** article where they decided to be
brief and not emphasize every problem. It's meant as advice and not a
scientific paper, so they've taken a short, clear-cut approach.
**Less than 3, given the pictures and the line spacing.
Irritants irritate me. Anyhow, when HCl mixes with water it turns
into hydrocholoric acid, one of the stronger acids. I don't want that
in my lungs.
Yes, that's how they kill people in the gas chamber.
Old May 16th 14, 02:51 PM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
Ann Marie Brest
I also would have assumed the opposite, had I not read the
articles, which prove our assumptions invalid.
The other articles on cabin fires went into nice detail
as to how hydrogen cyanide acts as a cellular asphyxiant by
binding to mitochondrial cytochrome oxidase.
They explicitly stated that smoke particles are not
deadly in an airplane crash.
So, what you, or I, would have assumed about smoke itself
being deadly, is apparently wrong.
If you still think your (and my) initial assumption is right,
then what we need is an article about cabin fires which says
both that the smoke particles are deadly, and, that a wet
cloth reduces them.
Otherwise, we're just making non-scientific assumptions.
Old May 16th 14, 04:05 PM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
RobertMacy
On Fri, 16 May 2014 06:51:56 -0700, Ann Marie Brest
...snip...
cloth reduces them.
Was there any mention of the radiated heat from these fires? After
personally experiencing a major fire in a building adjacent to our home, I
learned to apprecaite that aspect. For certain, a wet cloth over the head
would help shield. To see the potential shielding just envision sticking
your head into a barbecue pit with, and without, the wet towel. The air
into your lungs gets cooled so won't sear as much and at least your
corneas should remain intact.
Old May 16th 14, 06:00 PM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
Frank[_16_]
If I'm in a burning about to crash plane, I think the last thing I would
worry about would be the smoke
Old May 16th 14, 09:23 PM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
george152
As the airspeed would 'fan' the fires it would also take all the smoke
away for the few seconds you'd have to live
Old May 16th 14, 09:28 PM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
John S[_4_]
combustion gases
gases
smoke particulates;
cloth
particulates is
respiratory arrest.
quickly."
If you are the driver and can't see through the smoke, would you worry
about the smoke then or relax and resign yourself to your fate?
Old May 16th 14, 10:57 PM posted to alt.home.repair,sci.electronics.design,rec.aviation.piloting
george152
combustion gases
gases
smoke particulates;
dangers
cloth
particulates is
respiratory arrest.
quickly."
I believe you meant to type 'pilot' and I'd be doing everything within
my power to fly the aircraft and survive
Man eats own leg to survive car accident The Raven Aviation Photos 4 February 9th 07 07:13 PM
airplane crash, how to overcome bekah Piloting 20 May 21st 05 01:14 AM
Cabin aide recalls airplane crash horror NewsBOT Simulators 0 February 18th 05 09:46 PM
Homebuilt Airplane Crash Harry O Home Built 1 November 15th 04 03:40 AM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
