Battery for Becker radio
Old June 3rd 14, 04:41 PM posted to rec.aviation.soaring
HGXC[_2_]
Default Battery for Becker radio
I have a older model Becker radio with 5 presets. The presets do not hold the memory between use and my guess is the backup internal battery is dead.
Does anyone know where i can get the battery and how difficult is it to install on this radio. Yes I have called Becker and they would like me to send it in. I was hoping for a local (I fly in VT) easier to do solution if possible.
Dennis
Old June 3rd 14, 05:42 PM posted to rec.aviation.soaring
Soartech
Hi Dennis,
You can try looking at the manual for your radio at
http://www.beckerusa.com/downloadabl...6-63fc45dd5b8f
Or it is probably easy to open the radio and look for a battery. It is most likely a disc-shaped flat battery. Pop it out and look at the number. Should be an easy fix.
Dean
Old June 3rd 14, 06:56 PM posted to rec.aviation.soaring
Morteza Ansari
On Tuesday, June 3, 2014 8:41:02 AM UTC-7, HGXC wrote:
I have a older model Becker radio with 5 presets. The presets do not hold the memory between use and my guess is the backup internal battery is dead..
Dennis
The replacement is very easy, the hard part is getting the battery replacement. I couldn't find any source of it outside becker, the depth of the battery is critical and I couldn't find it anywhere. Finally I got it from Becker but only after a couple of months of back and forth. Others have drilled a whole through the case and mounted a larger battery on the outside. I will probably do that when this battery dies in a few years. Much easier and easily replaceable. Good luck.
Old June 3rd 14, 08:35 PM posted to rec.aviation.soaring
Soartech
Morteza Ansari, Do you recall the battery voltage? If Dennis knew that it would be easy
to retrofit a battery that would work.
Thanks.
Old June 4th 14, 12:06 AM posted to rec.aviation.soaring
Robert Dunning
Dennis
I got one from Paul Remde a few years back.
Rob
Becker radio repair [email protected] Soaring 7 March 10th 10 03:14 PM
Becker Radio question Fred[_4_] Soaring 7 June 22nd 08 05:06 AM
Becker 3201 Radio [email protected] Soaring 8 December 8th 05 03:08 PM
Becker radio AD Tom Serkowski Soaring 3 November 2nd 04 01:43 AM
Becker Radio battery John Giddy Soaring 3 October 20th 04 07:52 PM
