Need help with LX7007Compact connected to FLARM
Old June 6th 14, 05:36 AM posted to rec.aviation.soaring
GM
Default Need help with LX7007Compact connected to FLARM
Ok - this one is for all of you flight computer savvy guys in US-glider land because I for sure am at the end of my whits.
Here is the set-up:
I bought a used LX7007Compact. This is the one which does not have its own GPS receiver, so it needs an external source.
I also do have a PowerFLARM core which is/was feeding a Butterfly 57mm panel mounted display. The core is working fine - I get the two green boxes.
The LX is supposed to be connected to the FLARM core using the same cable used to run the Butterfly (8-pin to 6-pin) and both - the LX and FLARM - are supposed to be set to 19,200bps.
The LX is consistently displaying the warning 'No GPS data received'!
In an act of desperation, I hooked up my stone-age LX20 logger - same results! Only if I change the LX20 and LX7007Compact to tx/rx at 4,800bps will the LX7007Compact acknowledge receiving GPS data. If I interpret the FLARM manual correctly, no traffic thread info is transmitted at the 4,800bps setting, so that seems to be not the right way to do it.
The whole idea of using this set-up is to free up panel space and to get rid of the PDA and cables since the LX7007C does display the FLARM warnings just like or similar to the Butterfly does.
The LX7007C has been back to the factory and of course, it works flawlessly on their bench - go figure - but I have to take their word for it!
Question(s): does anyone use a LX7007C/FLARM combination successfully? If so, what are you doing differently? Is there perhaps something that needs to be set differently in the FLARM config.txt file?
Any serious reply is appreciated!
Uli
Old June 6th 14, 09:14 AM posted to rec.aviation.soaring
Hello Uli
did you set the communication speed to 19200 in the system setup in the "GPS" menu? We had similar problems with the LX7000 basic in our clubs Astir. I think it's now running with 4800bd from the Colibri because we didn't manage to get a stable connection with the Flarm.
best regards
Ueli
Old June 6th 14, 12:42 PM posted to rec.aviation.soaring
GM
On Friday, June 6, 2014 3:14:32 AM UTC-4, wrote:
Hello Uli
did you set the communication speed to 19200 in the system setup in the "GPS" menu? We had similar problems with the LX7000 basic in our clubs Astir.. I think it's now running with 4800bd from the Colibri because we didn't manage to get a stable connection with the Flarm.
best regards
Ueli
Hello Ueli,
correct, the System Set-up is the menu to set the baud-rate for the GPS, unless I am missing something.
Is the LX7007Basic also capable of displaying FLARM information?
Your experience reg. the 4,800bps does match mine.
Hmmmm.....
Thanks for the reply,
Uli
FLARM for SAR FLARM Soaring 57 November 21st 12 08:21 PM
Flarm in the US Steve Freeman Soaring 163 August 15th 10 01:12 AM
IGC FLARM DLL [email protected] Soaring 1 March 25th 08 12:27 PM
Headsets connected directly to a DVD player? dlevy Owning 7 June 30th 06 06:46 PM
FLARM John Galloway Soaring 9 November 27th 04 08:16 AM
