Elevator Tied Up or Tied Down?
Old June 16th 14, 03:45 PM posted to rec.aviation.soaring
WAVEGURU
Default Elevator Tied Up or Tied Down?
When tying down a glider, should the stick be tied back, with the elevator in the up position, or should the stick be tied forward, with the elevator in the down position?
Boggs
Old June 16th 14, 08:10 PM posted to rec.aviation.soaring
Bruce Hoult
If the tail of the glider is tied down then it's not going to make the slightest difference which way you do it. The only consideration is that the controls not be able to flap around. If you can do that by tying the stick forward then go for it, but it's usually much easier to tie it backwards. And don't forget, you're immobilising the ailerons just as much as the elevator.
Old June 16th 14, 08:14 PM posted to rec.aviation.soaring
Bill D
Boggs
If the elevator has drain holes, you want those down so internal condensation can drain out.
Old June 17th 14, 11:57 PM posted to rec.aviation.soaring
Andy[_1_]
This is most certainly not true if the glider has mylar seals on the elevator. In this case the elevator must be secured so the mylar seals are not deflected or they will either take a set and not contact the surface or, in the extreme, may separate. Same is true when the glider bits are stored in the trailer. The control surfaces should be restrained in the neutral position if mylar seals are used.
Andy (GY)
Old June 18th 14, 01:52 AM posted to rec.aviation.soaring
CindyB[_2_]
What's condensation?
Cindy B
Mojave Desert, CA
(last measurable precip - 3/1/14)
Old June 18th 14, 06:48 AM posted to rec.aviation.soaring
Cindy B
Mojave Desert, CA
Cindy, We know where you live.
We have a lot of it all year in Seattle
Heinz
What are the forces on a tied down glider? Eric Greenwell Soaring 40 August 21st 08 05:39 AM
FAA: FUNDING TIED TO MODERNIZATION Larry Dighera Piloting 1 March 28th 07 05:46 PM
Delco unit tied to Chinook Otis Willie Military Aviation 0 July 20th 04 10:11 PM
airbrake position while tied outside CK Soaring 18 January 19th 04 02:34 PM
