Power Flarm Ventus B antenna installation help!
Old June 17th 14, 02:29 AM posted to rec.aviation.soaring
Default Power Flarm Ventus B antenna installation help!
I purchased the power flarm core with the second antenna option. I am looking for recommendations; ideally photographs or diagrams of installed systems in Ventus B gliders.
Old June 17th 14, 08:27 AM posted to rec.aviation.soaring
Matt Herron Jr.
Since the fuselage is fiberglass, I glued them to the inside of the nose, just in front of the foot pedals (I only have two antennas) and everything works great. not sure where you should put the 2nd flarm antenna though.
Matt H
Old June 17th 14, 03:01 PM posted to rec.aviation.soaring
Richard[_9_]
Tie wrap to the front of the air vent that goes vertical.
Richard
www.craggyaero.com
Flarm installation in a Duo Discus Juanman Soaring 5 September 18th 13 07:18 PM
FLARM Installation Boise Pilot Soaring 11 April 5th 12 03:25 PM
ASW 27 or 27-18 406 ELT & antenna installation chipsoars Soaring 6 October 10th 09 04:07 PM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 06:53 PM
antenna installation in a glider? ken ward Soaring 5 May 19th 04 07:02 PM
