Kestrel 19 turbulator tape
Old July 9th 14, 10:34 PM posted to rec.aviation.soaring
Lee Davidson
Default Kestrel 19 turbulator tape
has any one fitted turbulator tape to a kestrel or know where the best
position for it is, or if it's worth putting on at all.
Old July 10th 14, 12:07 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Why not ask Glasfaser? They sell zig-zag turbulator tape in several
thicknesses and would surely know if it helps on a Kestrel and, if so,
where to put it. Its fitted to my Libelle and evidently makes a
difference: the BGA has separate handicaps for an H.201 and an H.201 with
turbulators: the latter is slightly increased.
Glasfaser are at http://www.streifly.de/
The site is dual language (German and English). I've found them to be
most helpful and easy to deal with.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 10th 14, 01:10 PM posted to rec.aviation.soaring
On Wed, 09 Jul 2014 23:07:19 +0000, Martin Gregorie wrote:
[zig-zag turbulators are] fitted to my Libelle and evidently makes a
with turbulators: the latter is slightly increased.
I should have said that this is full span turbulation on the lower
surface and is placed just ahead of the undercambered part of the lower
surface.
It delays flow separation on the undercambered part of the undersurface
at low AOA: this reduces drag at higher airspeeds.
org |
Old July 10th 14, 05:34 AM posted to rec.aviation.soaring
Frank Whiteley
I once asked Peter Masak and he suggested starting at 67% of chord but didn't think it would make a lot of difference, given the airfoil.
I later also discussed with Udo Rumpf more generally about the Wortmann FX67 airfoil series. His reply:
" The FX 67 airfoil can realise its potential.
It will fall short of any airfoil that came after, in one case before, as in the case of the ASW20.
I only know of one variant, the LS3 which performed reasonably well.
for a glider of that period. I do not know what the changes are on the LS3 airfoil, if any.
The sharp leading edge of the FX67/15 looks good for higher cruise.
but is detrimental in climb. combined with the high camber and the pronounced pressure drop in first 35% followed by a extreme pressure recovery make the airfoil very sensitive to all sort variables.
The bottom surface is very good and if all is right, the hinge line at 80% should act as a trigger for transition but a turbulator at 75% chord should do the trick
I recommend to place a turbulator on top at 40% chord only on the 40% outboard section of the wing. This turbulator is akin to small 3/16 cylinders (with sharp defined edges) about .040" high and spaced about an 1.25" apart.
The reason, the airfoil is Reynolds number sensitive.
this will help to keep the flow attach at slow speed and provide effective aileron control. This will not help regarding gust sensitivity in thermals, which it very pronounced with the thinner FX67 variant.
Udo"
With upper and lower mylar seals, the Kestrel 19 aileron control is already very good, the upper surface placement seemed moot. I considered zig-zag for the vertical as my rudder (the larger chord Glossop mod) seems to 'hunt', that is, suffer from flow separation on one side then the other when flying straight. Haven't done so. Tom Knauff suggested better sealing on the rudder was needed.
Still on my maybe do list.
Frank Whiteley
Turbulator Tape Placement Question John DeRosa Sky Soaring Chicago IL Soaring 2 February 23rd 04 08:11 AM
TURBULATOR TAPE ON VENTUS B Ventus B Soaring 5 February 18th 04 08:27 PM
LS-4A Turbulator tape question Joe Lacour Soaring 1 October 25th 03 11:39 PM
Elevator Turbulator tape question JJ Sinclair Soaring 39 October 17th 03 02:35 PM
Dear Jack - Elevator Turbulator tape question Dave Martin Soaring 2 October 14th 03 08:11 PM
