Noise issues with Oudie 2 in a couple different aircraft
Old July 19th 14, 05:19 AM posted to rec.aviation.soaring
Doug Mueller
Default Noise issues with Oudie 2 in a couple different aircraft
Is anybody else having noise issues when the Oudie is hard wired
to ships power. I know two aircraft that have the squelch turned on
to try to drown out the noise on the radio. I believe it is from the
Oudie while it is being charged. I recently added the Oudie to the
aircraft and now the radio will not cancel out after receiving a
transmission. I have tried wrapping the wiring of the oudie and the
gps cables to try andshield them but it isnt helping. After I turn off
the Oudie the radio returns to normal. Thanks, Doug
Old July 19th 14, 04:49 PM posted to rec.aviation.soaring
Dan Marotta
You might try ferrite beads (baluns) on the power cable to the Oudie
*and* on the power lines to the radio.
Or replace the Oudie with a Dell Streak 5 (sorry).
Dan Marotta
Old July 19th 14, 05:17 PM posted to rec.aviation.soaring
Tim Taylor
You did not say what you are using for a power converter. That is the first place to look, cheap power converters make lots of noise.
Old July 20th 14, 05:09 AM posted to rec.aviation.soaring
Bill T
I had the Oudie powered through the supplied 12V to 5V interface cable supplied with the Oudie. I used a Y power cable from the battery to connect to the interface cable and the other side of the Y to ships power. I did not have the Oudie powered from the aircraft bus bar.
I used the Oudie supplied interface to power the Oudie and the Nano from the aircraft battery and also to move data between Oudie and Nano. Task data to the Nano and GPS data from Nano to Oudie, and final retrieval for final Nano igc file from Nano to Oudie. Nano on the USB side and the Oudie on the RJ 45 plug.
No noise on the radio.
Hope the helps.
BillT
Old July 20th 14, 09:59 PM posted to rec.aviation.soaring
2G
Besides adding the ferrite beads as already suggested, you should take a look at the power distribution. Ideally, all power returns (sometimes erroneously called "grounds") should come to a common single-point ground. Daisy-chaining these returns to various instruments will couple electrical noise from one to others. Have that single point connection as close to the battery as possible, with the lead going to the battery as large as practicable.
Tom
Old July 21st 14, 01:29 AM posted to rec.aviation.soaring
jfitch
Not an Oudie but the closely related Avier. I had used this last year without issue, just reinstalled it and now the radio breaks squelch with it on. After some tracing I have discovered it is the unit itself, radiating modulated RF, mostly down its data/power cable. Disconnecting the cable at the PDA end solves most of the problem. Disconnecting at the vario end sometimes solves it. Just touching a screwdriver (as an example) to the shield of the Avier mini-usb plug causes it with no other cable plugged in. Seems to be related to the LDC screen driver, as it is dependent to a large extent on what is being displayed on the screen. Switching the (switching) power supply to it on and off makes no difference. I was able to mitigate most of it by careful reroute of the data/power cable keeping it away from the radio and close to other conducting material. But it is a bit black magic. I didn't have a ferrite to try and will try that next opportunity.
Old July 21st 14, 07:35 AM posted to rec.aviation.soaring
JS
Ferrite beads ARE magic.
Old July 21st 14, 01:19 PM
jherzog jherzog is offline
Junior Member
First recorded activity by AviationBanter: Oct 2011
I have an Oudie 2 coupled to 12V power and exchanging data with an LxNav Nano using the cable kit that comes with the Oudie. I experienced significant radio noise -- usually enough to break the squelch. I saw a prior posting by John DeRosa, who recommended this inexpensive yet overpriced ferrite choke core from Radio Shack: http://www.radioshack.com/product/in...ductId=2103222
I installed it around the Oudie power/data cable, about 1/2 inch from the Oudie-side of the cable -- I have had no radio issues since.
Old July 21st 14, 07:36 PM posted to rec.aviation.soaring
Doug Mueller
with an LxNav
experienced
saw a
inexpensive yet
http://www.radioshack.com/product/index.jsp?
productId=2103222
from
jherzog
Thank you to all for replying. I will try this solution first and report
back. Doug
Old July 24th 14, 12:49 AM posted to rec.aviation.soaring
6PK
Not an Oudie but the closely related Avier. I had used this last year without issue, just reinstalled it and now the radio breaks squelch with it on.. After some tracing I have discovered it is the unit itself, radiating modulated RF, mostly down its data/power cable. Disconnecting the cable at the PDA end solves most of the problem. Disconnecting at the vario end sometimes solves it. Just touching a screwdriver (as an example) to the shield of the Avier mini-usb plug causes it with no other cable plugged in. Seems to be related to the LDC screen driver, as it is dependent to a large extent on what is being displayed on the screen. Switching the (switching) power supply to it on and off makes no difference. I was able to mitigate most of it by careful reroute of the data/power cable keeping it away from the radio and close to other conducting material. But it is a bit black magic. I didn't have a ferrite to try and will try that next opportunity.
Ditto. Same issue with the Avier/Vertica2. I did try the ferrite beads as well and it did nothing. Sent in my antique Dittel radio to Nick in Florida who charged me $175 and sent it back with a clean bill of health, could not find anything wrong with the radio. I was going to mess with the internal squelch than but when plugged all in; it all worked!
Talking about magic?!
6PK
Oudie Issues vontresc Soaring 4 July 16th 14 04:44 AM
Why bother about light aircraft noise. [email protected] Piloting 36 July 13th 05 09:52 PM
Newer aircraft mx issues SAC Owning 4 July 6th 05 05:59 PM
Couple of Plugs: Stan Shannon and Wicks Aircraft Larry Smith Home Built 8 November 8th 03 01:22 AM
ISO back issues Combat Aircraft magazine mark e digby Military Aviation 0 August 12th 03 05:39 PM
