Winter 57mm ASI needed.
Old July 22nd 14, 03:23 AM posted to rec.aviation.soaring
Default Winter 57mm ASI needed.
I am in need of a Winter 57mm ASI (0 - 160 kts.)Not enough room in the panel so have to take out the 80mm.
Old July 22nd 14, 03:53 AM posted to rec.aviation.soaring
Paul Remde
Hi,
I have new Winter 7423 airspeed indictors in stock. You can see details and
order he
http://www.cumulus-soaring.com/winter.htm#W-7423
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_____________________________________
Old July 22nd 14, 02:02 PM posted to rec.aviation.soaring
Chris Aniol
I should have said " used "
Spring Cleaning Early: Dell Streak 5 pkg, Winter Vario 57mm, more Evan Ludeman[_4_] Soaring 2 December 31st 12 12:14 AM
Winter 57mm Altimeter Ventus2NZ Soaring 9 November 21st 11 10:49 PM
Winter 57mm Altimeter for sale Juanman Soaring 0 May 13th 10 08:06 PM
Wanted: 57mm B40 John C Soaring 0 May 8th 10 02:24 AM
Need A 57mm Borgelt B40 [email protected] Soaring 2 March 14th 05 03:22 AM
