2014 US Modern and US Club Class Nationals - Assigned Task calledtoday! FANTASTIC!
Old July 23rd 14, 09:09 PM posted to rec.aviation.soaring
Sean Fidler
Default 2014 US Modern and US Club Class Nationals - Assigned Task calledtoday! FANTASTIC!
http://www.ssa.org/Contests?cid=2248...lass+Nationals
I am really happy to see this! Its of course a very strong day down there (finally). I would be interested in hearing everybody's feedback as to how they liked the Assigned task today vs. the more typical Turn Area Tasks.
Maybe the CD even put a time limit on the start cylinder (say 15 minutes)!
Just kiddin ;-)
Sean
Old July 24th 14, 02:12 AM posted to rec.aviation.soaring
lynn
Just kiddin ;-)
Sean
By Texas norms, it was a weak day for half the task with massive gaggles along the first leg (68+/- miles). The glut of sailplanes at each thermal seemed somewhat hazardous. Lift in the range of 300fpm and max heights around 5000 to 6000MSL with ground elevations of 700 to 1300ft. The last 60 to 70 miles lacked any clouds and lower max gains as one approached the finish. Wishing for a repeat of 2011 summer when the norm was 600 to 1200fpm and cloud bases of 8000 to 12000msl.
Old July 24th 14, 02:17 AM posted to rec.aviation.soaring
Bill D
Just kiddin ;-)
Sean
Apparently Kathy Fosha was able to make the most of it. Congratulation to her for a first place day.
Old July 24th 14, 04:35 AM posted to rec.aviation.soaring
Tony[_5_]
Just kiddin ;-)
Sean
It was a fun and challenging day. Just what you should expect I suppose. Of course we were all hoping for blazing speeds and to be home in less than 4 hours. Clouds did not develop as well as we were hoping. There were a few sizable blue holes on course and the last leg home was blue for everyone. I started early and the gaggle didn't catch me until the second turn. Everyone got along well and flew nicely. We have a lot of very skilled pilots here. As far as I could tell in Club Class at least, everyone enjoyed the assigned task and had fun.
Old July 24th 14, 05:32 AM posted to rec.aviation.soaring
Sean Fidler
Glad that it worked out and that you had fun. Definitely a more challenging kind of task! Congrats to everyone for making it around.
Just kiddin ;-)
Sean
Old July 24th 14, 12:56 PM posted to rec.aviation.soaring
Tony[_5_]
Modern Class was not so lucky.3 landouts, 1 fired the motor, and 1 didn't attempt the task. Still not too bad though.
Old July 24th 14, 01:54 PM posted to rec.aviation.soaring
How is flying around with the gaggle all day in the blue more challenging?
UH
Just kiddin ;-)
Sean
It was a fun and challenging day. Just what you should expect I suppose.. Of course we were all hoping for blazing speeds and to be home in less than 4 hours. Clouds did not develop as well as we were hoping. There were a few sizable blue holes on course and the last leg home was blue for everyone. I started early and the gaggle didn't catch me until the second turn. Everyone got along well and flew nicely. We have a lot of very skilled pilots here. As far as I could tell in Club Class at least, everyone enjoyed the assigned task and had fun.
Old July 24th 14, 01:58 PM posted to rec.aviation.soaring
Sean Fidler
Well, here is to Club Class for getting around their 200 mile assigned task! Great job pilots and tasking commitee! I am sure both classes enjoyed challenge. It looks like it mixed up the standings a little too.
Good luck to both classes on the final day! I hope you get the opportunity to fly another assigned task today. I feel as if 2 of 7 total contest days with assigned tasks would be ok. 1 of 7 does not feel like enough assigned tasking for a Nationals. I would think ½ assigned tasks in the pure class Nationals would be a good target. For club/modern perhaps ⅓ is the right mix?
Thoughts?
Sean
Old July 24th 14, 02:05 PM posted to rec.aviation.soaring
Sarah Arnold
We had a fantastic time. The gaggle had spaced out nicely by the end of the first leg, and we had clouds for most of the day. It was a fun and challenging task. I hope we get another today.
Sarah Arnold
Old July 24th 14, 03:51 PM posted to rec.aviation.soaring
Sean Fidler
Hank,
Clearly you don't like the Assigned Task much based on your very exciting, enthusiastic description of it. ;-) Geeze.
I see Assigned Tasking as the best thing that sailplane racing has to offer.. In my experience, Assigned Tasks are far, far more fun and rewarding at all levels. They also are far too rare in the US. Ill stand on the podium for a second and explain...
GAGGLES: In regards to gaggles, even if the group starts together (not AT ALL exclusive to assigned tasks by the way), eventually the gaggle will break up. Usually along the first leg. The great thing about Assigned Tasks is that pilots actually know how they are doing relative to other competitors. In an Assigned Task you are actually racing (almost!) and not just flying cross country together (sorta) and looking forward to seeing a score calculated by a scorers computer at the end of the day (often hours after you land) to tell you what it all meant while you were flying.
Flying together during the Assigned Task is not a bad thing (for me). It's a great thing! It's called racing! Faster pilots will naturally get ahead, slower will fall behind and so on. The learning experience that happens during these rare (US) assigned tasks is extreme and highly valuable. I have learned 10x faster during Assigned Tasks vs. Area Tasks. I am also having 10x more fun! And again as the gaggle thins out along the task there is actual meaning to that pecking order that forms (see above). How fun!!!
I would argue that gaggles are actually less common in Assigned Tasks at times. Unlike wide Turn Area Tasks, you can't "cut the corner" and catch up to the gaggle in every turn area like you can in Turn Area Task. This ability to "cut the corner" (or just randomly reconnecting) actually allows the gaggle to reform again and again in Turn Area Tasks. I actually saw this happen often at Perry this spring.
In an Assigned Task trailers can only cut out a maximum of 2 miles to catch back up to the gaggle. Furthermore the leaders can (if they wish) simply turn early and eliminate the chance of trailers catching back up to them. They are only giving up 2 miles of distance. Note: I think we should remove the extra distance concept from Assigned Tasks for this reason. Assigned Tasks should be about pure speed around a simple set track, not about time or the ticky, tacky practice of adding extra distance or complex scoring programs. Assigned Tasks are simple races around a set track and should not be complex in any way.
TURN AREA TASKS ARE MORE A GAME OF CHANCE (LUCK): In general, the whole reason Turn Area Tasks were created is to account for broad handicap ranges, broad skill ranges and difficult or unpredictable weather conditions. The Assigned Area task is, by definition, a compromise and a softening of the difficulty of the Assigned Task. In a Turn Area Task, there is no need to go to any particular point, if that spot doesn't look good to you, or there is not perfect cumulus cloud gleaming above it, you can just go somewhere else that looks better. That is fundamentally less challenging! Wide radius Turn Area Tasks provide pilots a tremendous amount of choice and the ability to constantly take chances on vastly different routes to entirely different turning points. In a 20 mile radius Turn Area for example, two pilots can easily be 30+ miles in terms of where they finally choose to turn. That is not a good thing when the conditions are good. Turn Area Tasks becomes a weather guessing game. Weather by definition is not an exact science (especially on a micro scale). Choosing a path in a Turn Area Task is often a crapshoot, lets be honest.
THE IMPORTANCE OF TIME MANAGEMENT AND EXPENSIVE, COMPLEX GLIDE COMPUTERS IN TURN AREA TASKS: Unlike an Assigned Task which has no time limit, Turn Area Task (and MODIFIED Assigned Area Tasks) are almost completely focused on the pilots ability to effectively managing minimum time (or in the case of the Modified Assigned Area Task, to manage the complex process of adding on additional turnpoints AND time). Accurately estimating this time decision and returning to the finish efficiently during and Turn Area Task is extremely difficult to do well. A mistake in this KEY element can make or break your score for that day even if you flew perfectly up until that moment. Turn Area Task always result in pilots essentially "guessing" when to turn for home many miles away. That is unless you spend 5k on a top of the line glide computer! This time challenge with Turn Area Tasks has greatly increased the importance of expensive, complex glide computers (often the single most expensive item in the glider (around $5000 USD). The Glide Computer market has become a source of great competition among the various instrument manufacturers as they develop better features, brighter screens, better software, etc. It is a clear competitive advantage to own and master an expensive full featured Glide Computer when Turn Area Contests are almost exclusive! A reliance on complex glider computers is an obstacle to new pilots.
I could go on and on...but I will stop here for now.
Sean
UH
Just kiddin ;-)
Sean
Polish Gliding Commission bans modern ships from there Standard Class Nationals! [email protected] Soaring 9 February 8th 14 05:02 PM
2014 Sports Class Nationals Texas Soaring Soaring 0 December 10th 13 09:09 PM
2012 Moriarty Super Regional Club/Modern Class contest mike Soaring 5 November 16th 11 04:36 AM
German Club class championship calls a +500KM task! Bob Soaring 17 June 2nd 09 03:51 AM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
