Another mid-air (UK)
Old August 4th 14, 12:33 PM posted to rec.aviation.soaring
Default Another mid-air (UK)
http://www.dailymail.co.uk/news/arti...#ixzz39BhomNQI
7U
Old August 4th 14, 01:13 PM posted to rec.aviation.soaring
Neil Goudie[_2_]
Don't fall into the trap that on-line newspapers date stamp stories with
today's date. This article relates to an event on Saturday 26 August
2014.
For the record there have been 4 notifiable Midairs in the last 2 years in
the UK.
All have had successful outcomes (in terms of casualties) and all with 1
pilot bailing out and the other pilot(s) landing.
A success story in terms of pilot training for the positive outcome but
more of an issue in terms of why they are occuring in the first place.
I won't speculate as the last 3 have occurred in the last 3 months and I
haven't read the formal reports.
Neil
7U
Old August 4th 14, 02:21 PM posted to rec.aviation.soaring
son_of_flubber
On Monday, August 4, 2014 8:13:54 AM UTC-4, Neil Goudie wrote:
This article relates to an event on Saturday 26 August 2014.
July?
Old August 4th 14, 03:10 PM posted to rec.aviation.soaring
Neil Goudie[_2_]
July?
Yes July. I flipped by calendar this morning at work.
Old August 4th 14, 05:11 PM posted to rec.aviation.soaring
Ramy[_2_]
Still hoping to hear about Flarm status in all the midairs mentioned and if they all happened in crowded gaggles. Understandably Flarm effectiveness diminishes in crowded thermals.
Ramy
Old August 4th 14, 06:55 PM posted to rec.aviation.soaring
Stats Watcher
mentioned and if
effectiveness
Ramy
Of the 3 incidents, 3 of the 6 gliders are confirmed as carrying
FLARM, the status of the other 3 is still not confirmed, so they too
could have been.
In 1 incident 2 FLARM carrying gliders flew alone in a thermal for 13
turns before hitting each other.
Overall given the number/rate of Flarm carrying gliders in the UK
they are significantly over represented in these recent stats. The
conclusion maybe that for some reason carrying FLARM increases
the risk of collision compared to not carrying it! ... discuss...
Neil Goudie[_2_]
2014.
the UK.
Neil
7U
Neil Goudie[_2_]
2014.
the UK.
Neil
7U
Old August 4th 14, 08:08 PM posted to rec.aviation.soaring
[email protected][_1_]
A working hypothesis is that FLARM lulls pilots into a sense of false security and psychologically offloads the responsibility of traffic separation onto a "black box". Probably especially true with younger pilots who rely on electronic devices to do tasks for them on a daily basis.
Similar behavior occurs when pilots take the output of their NAV systems as fact. Some really smart, highly experienced pilots have landed in some really poor spots because the Black Box said they could get home, notwithstanding there was clearly a mountain range in the way and the required glide angle was uphill. They believed in the Black Box output more than on their own eyes.
This also occurs on the White- Inyo Mt Range in CA, USA. A procedure was initiated 15-20 years ago to reduce midair potential using a standardized position reporting scheme. Pilots became complacent by assuming they knew where all gliders were located due to radio reports. Such folks can easily be identified by how upset they sound when a NORDO glider suddenly appeared in their environment.
This behavior is also seen in people who own cars. They no longer "preflight" the oil, tires or other systems because a system will (allegedly) do it for them.
A CFI friend has a large sign in his flight kit that says "COMPLACENCY KILLS".
Spot On!
I also believe that anything (NAV displays, FLARM, visual "Thermal Maximizers") that causes you to focus significant amounts of time inside the cockpit, are a serious detriment to safety and probably X-C performance. Somebody famous once said "90% of what you need to know is outside the cockpit" That is still true, in my opinion.
Old August 4th 14, 08:21 PM posted to rec.aviation.soaring
Ramy[_2_]
Before we can try to draw any conclusion we need more data of course. It shouldn't be too dificult to confirm if the other gliders had flarm. If only one glider has flarm it is as good as no flarm. The pilot in the pics mentioned that the other glider came out of nowhere. This should not happen with working flarms.
BTW I believe PowerFlarm has big advantage over the classic flarm who only gives you few seconds of collision alert while PowerFlarm gives you a better display providing situational awareness so you have plenty of warning that someone is nearby and how many gliders are nearby in the gaggle.
Ramy
