Glide Navigator II Problem
Old September 6th 14, 08:28 PM posted to rec.aviation.soaring
rlovinggood
Default Glide Navigator II Problem
My GNII, running on an iPAQ 3955, won't load files.
I have the program file under the "Start" menu.
I have the turnpoint file, in *.txt format, under "My Documents."
I have the airspace file, in *.sua format, under "My Documents."
The same files are on the storage card.
I've been using this setup for many years, but all of a sudden, it doesn't work.
GNII starts on the pda, goes to the screen which allows selecting to use GPS input or run as a simulator, but when it gets to the screen of "Initializing GNII" and "Loading files", it hangs, as if it can't find the files.
Greatly appreciate any help.
Ray Lovinggood
LS1-d
W8
Old September 6th 14, 09:52 PM posted to rec.aviation.soaring
Gregg Leslie[_2_]
Hi Ray,
If my memory serves me correctly the turnpoint file extension should be a
dat, u could save the turnpoints on your CF card as .dat. The only other
time
that happened to me was trying to load to many waypoints.
doesn't
work.
files.
Ray Lovinggood
LS1-d
W8
Old September 6th 14, 10:07 PM posted to rec.aviation.soaring
Gregg Leslie[_2_]
Hi Ray,
time
doesn't
work.
files.
Ray Lovinggood
LS1-d
W8
Old September 7th 14, 12:23 AM posted to rec.aviation.soaring
On Saturday, September 6, 2014 5:07:27 PM UTC-4, Gregg Leslie wrote:
Hi Ray,
time
doesn't
work.
files.
Ray Lovinggood
LS1-d
W8
Ray; Check your CF card properly inserted all the way into slot.
Old September 8th 14, 12:24 AM posted to rec.aviation.soaring
Paul Remde
Hi Ray,
You need to use waypoint files in the Cambridge .dat format. Airspace files
must be in the Tim Newport-Peace .sua format. Using the correct files will
solve the problem. You may need to delete the "wrong" files to be able to
get into GN II to select the correct files.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"rlovinggood" wrote in message
work.
Ray Lovinggood
LS1-d
W8
Old September 9th 14, 04:57 PM posted to rec.aviation.soaring
David Prather[_2_]
Hi Ray,
One more tip... delete any waypoint files that are on the 302 itself, if
any, and don't re-load them. My PDA wouldn't recognize the 302 because the
302 had a corrupted file on it. It took me forever to find the problem, but
deleting the file with a terminal program cured it and it's been working
all season.
-Dave Prather
At 23:24 07 September 2014, Paul Remde wrote:
Hi Ray,
files
will
Best Regards,
Paul Remde
work.
GPS
"Initializing
Ray Lovinggood
LS1-d
W8
Old September 10th 14, 02:05 PM posted to rec.aviation.soaring
rlovinggood
Thanks for all of the suggestions. I'll try them as soon as I can make time and report results.
Ray
W8
Old November 6th 14, 07:13 PM posted to rec.aviation.soaring
Six-Seven
You may also want to post to the GNII Yahoo Group https://groups.yahoo.com/neo/groups/GNII/info.
Old November 6th 14, 10:06 PM posted to rec.aviation.soaring
Six-Seven Romeo
As to the idea of deleting the contents of the 302. This has happened to me also. The belief is that it has something to do with the memory wrapping feature (overwriting the oldest files) doesn't work correctly in some cases.
I have more information and how-to documentation (from many sources) at http://aviation.derosaweb.net/cambridge/#errors.
Good luck, John
New Version of Glide Navigator II Available Paul Remde Soaring 3 February 2nd 08 08:49 AM
Glide Navigator II v2.41 problems charlie foxtrot Soaring 2 April 4th 06 02:32 PM
Glide Navigator II help [email protected] Soaring 7 March 24th 06 04:16 PM
New version of Glide Navigator II Available Paul Remde Soaring 0 March 15th 06 03:43 PM
Bugs in Glide Navigator II David Martin Soaring 0 July 28th 03 04:35 PM
